Question about Fellowes PS80C-2 Shredder
I have a NoviTech PS-064/B shredder. First nylon gear off the motor drive gear is stripped in one spot. The only two numbers I've seen for NoviTech [including the one that was on a sheet of paper that came with the shredder] are never answered. Is it possible to find parts for these shredders or simply not possible?
3 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: REPLACEMENT INTERMEDIATE DRIVE GEAR FOR NOVITECH
Get me the model and serial number or just call Fellowes direct. They will sell you the part.
If not. Call me with the information and I can order it for you.
727-773-8973
Posted on Sep 07, 2009
SOURCE: NoviTech Paper Shredder will not feed paper forward.
Solution 1 worked for me. I unscrewed all 7 screws, pulled apart the cover carefully. Beware, there are wires attached. you can lay it side by side.
The activator is the white plastic thing. You need to make sure that it sticks out and as the paper goes from the top, through the cover, it hits the white activator.
At the end of the white activator, you see it has some plastic to push on the metal strip. This engages the forward motion. You'll here a click if you test the paper going through. This click is the sound of telling the motor to roll forward.
I think it got knocked out of place when I tried to insert a CD into it. Luckily, I didn't buy another shredder because of the Best Solution in this forum. So thanks for your help!
Posted on Aug 01, 2010
The motor runs, but paper does not feed in
quite likely the drive gear is stripped .normal are plastic/nylon
Oct 29, 2015 | Techko SH2106PA Shredder
Gears are not rotating; motor works though
I guess you have made sure that the cutters are not jammed by bits of paper and card?
Mar 23, 2014 | Office Equipment & Supplies
My Novitech Model PS-012A is stuck in auto mode and has the same problem as noted on this page for the Model PS-106/B2
For this internal technical problem you need to contact Novitech for their technical support. Call them at this number: 1-866-238-2490 for help.
May 20, 2011 | Office Equipment & Supplies
REPLACEMENT INTERMEDIATE DRIVE GEAR FOR NOVITECH PS-026/B2 SHREDDER
727-773-8973
Sep 05, 2009 | Fellowes DM15C Shredder
NoviTech Paper Shredder PS-045/B stops working after a while.
I have workrd on shredders for 17 years. you need to spray a light wait oil in to the paper shut. It is a catch 22 paper dust & paper builds up in them and the covers need to come off and be cleaned out or gears start stripping or braking.
good luck
C.W.H. ( typboy)
Jan 22, 2009 | Office Equipment & Supplies
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Aug 27, 2008 | Fellowes DM15C Shredder
Can't find part number
I would like you to find the bar code on your shredder. Once you find the bar code label look right under the bar code strip and get the numbers. It is a serial number.
Apr 14, 2008 | Office Equipment & Supplies
Novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Feb 12, 2008 | Fellowes DM15C Shredder
Fellowes PS80C-2 Shredder Logo
106 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
