Question about Frigidaire FEQ332E Electric Dryer
Hi, my FEQ332ES0 stopped starting up (after a day of no use), and it makes a faint buzz when I hit the start switch. The tumbler light works, and I OHM'd out the thermal limiter and it looks fine. Any ideas where to probe next?
  • BmanMA Oct 15, 2010
    I did the test today that I have read on other posts here, where you give the drum a jump start manually while holding the door switch closed. It worked. Wifey was able to get it to start at least 2 more times by itself after that.
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
Testimonial: "Awesome wealth of knowledge with fast replies. Thanks so much!"
Egine turns over, battery is good but the is no starting
could be starter possibly or ignition switch or key and tumbler or fuel pump there is so many possiblities, turn the key over and listen for the buzzing from the pump. if it has that then the fuel pump is working. you can hold the key in crank and see if it starts that would suggest key and tumbler or ignition switch.. if it is a standard you can try bomb starting it to see if it starts. if it does that means possibly starter
Jan 28, 2011 | 2005 Scion xB
1995 Mercedes S 320 won't start. battery is fine
I know on the L.H. (previous fuel injection system) models there was a module called a base module that worked as a big overvoltage relay and powered up all the control units for the engine and drivetrain,they had 4 to 6 10amp. fuses in the top and theywould blow fuses and sometimes fail themselves causing no start conditions. I beleive yours is an H.F.M. system. I used to do roadside and i'm also a mercedes benz tech. The first thing I would try would be to put the car in nuetral and see if it starts. the nuetral safety switches of that era are problomatic. next I would check my brake light fuse in the engine compartment fuse box. That fuse also powers the starter relay-even though it doesn't state that on the fuse schematic. Also to answer your question about a lockout relay-yes there is but they rarely cause a problem. I hope I have been helpful
Jul 06, 2009 | 1995 Mercedes-Benz S-Class
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Dryer, gas model #ddgg57806clad stopped working after it finished the first load of the day. It doesn't feel like it's totally connected. The timer clicks, but it doesn't feel like there's power going to...
Hi, I'm posting my own solution to my problem. Thank you fixya and the many people who had a similar problem who sent in solutions to others on this site.
The door switch to the dryer was hitting a worn out area of the gasket surrounding the door and prevented a connection to the tumbler. After manually checking the tumbler to make sure it wasn't stuck, I temporarily put a piece of masking tape over the switch with the door open. Then I turned the timer knob on while the door was open to see if the dryer started and voila! it started. Hope this solution helps someone else. Iris
Mar 07, 2009 | GE Dryers
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Frigidaire FEQ332E Electric Dryer Logo
482 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
