Question about Singer 7466 Mechanical Sewing Machine
I can't get the bobbin thread to pick up. I just changed to a heavier needle and thread above. Would not pick up with light thread in bobbin, so loaded a bobbin with heavier thread, also. Took apart and cleaned, still no luck.
    Genius:
  • 1,788 Answers
I don't think that you can mix threads and have it work smoothly. They always said to have about the same weight and type in both.
Posted on Oct 15, 2010
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
Why doesn't needle thread pick up bobbin thread?
1. Make sure the bobbin has about two inches of thread away from the bobbin. Also, make sure the bobbin has been adjusted properly for tension.
2. While turning the hand wheel keep the needle thread pulled towards the back. The bobbin thread should come up above the throat plate.
NOW, IF THIS DIDN'T WORK: Take the machine to a repairman to be timed. This is when the bobbin hook (sharp thing around bobbin) picks up the needle thread. It has got to be at exactly the right time when the needle is going back upward.
Nov 18, 2015 | Sewing Machines
I have a Juki HZL-K85. I changed to a heavier thread for outdoor material, the thread bunched up and the machine made a crunch noise. I got the fabric free, but now the bobbin thread is not being picked...
Check the needle to see if it is bent. If not then check the needle to hook timing. Turn the hand wheel until the needle is at it's lowest position. Start to bring the needle upward. As the needle gets to the edge of the hook/bobbin race the point of the hook should pass slightly above and behind the needle. If it isn't the timing is out. I would suggest bringing it to a trusted sewing machine repair person to reset the hook timing and check for any other damage.
Sep 14, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
The bobbin thread appears up through the hole by the foot, but the needle doesn't seem to be picking it up and advancing the thread properly, so when I sew, the bobbin thread isn't engaging. I have a JC...
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Sewing Machines
Will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Jul 04, 2009 | Janome 6019QC Mechanical Sewing Machine
Needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Feb 18, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 7466 Mechanical Sewing Machine Logo
77 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
