Question about Ovens
I can set the power and the time but when start is pressed the microwave runs but the table does not rotate
  • Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 15, 2010
Power failure,now 000 is flashing on oven exterior
If the 000 is on the display left of centre, then you possibly just need to reset the clock. from left to right-....press the first button to activate the clock setting phase....press the next button to pop out the rotating timer adjust and set the time.
If it is the display above the centre control dial pls repost with the full Enr from the rating plate.
Feb 25, 2013 | Neff B1881 Single circotherm super...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Yesterday I "self-cleaned" by oven.
    Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
    Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
    Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
    Feb 18, 2011 | Jenn-Air Ovens
    How do i set the power level on my microwave oven over the range
    most of them always start on full power..if you want to lower it..time cook, power 10 would be 10% or power 30 would be 30% like this...so time cook, power ,start
    Jan 23, 2011 | Ovens
    No heat and no rotate of the turn table. Everything else seems to be working as designed. This is the microwave
    Welcome to fixya
    Hello
    I have a solution for this
    Press Ok, Accept or replay so we may get started
    Your pre-solution is coming up shortly
    PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
    Jan 16, 2011 | GE JKP85 Electric Double Oven
    How to change the fuse on Kitchen Aid model KEMS308SBL02 combination oven and microwave. The oven door locked after a power outage this week and now the oven won't come on.
    Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
    Dec 04, 2010 | Ovens
    Microwave has power...light lights and turn table turns but nothinng heats up and there is a smell of burnt electrical items
    heatman101
    Nov 19, 2010 | KitchenAid KEMC378KSS Electric Double Oven
    Sharp MW won't shut off
    Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
    Jun 14, 2009 | Ovens
    How to set time with new control board?
    You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
    This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
    Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
    KitchenAid Superba Microwave/Oven, Microway Door message
    "I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
    Dec 20, 2008 | Ovens
    Ovens Logo
    44 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
