Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Cannot engage blades on john deere 165 hydro...my first time using a ride mower....do I push the lever on my left forward to make blades cut?
tbirdfan1
  • 3051 Answers
SOURCE: John Deere ride on mower L100 17 hp.
Hello there:
I would first check to see if there is any binding in the deck belt's or gears and make sure that the deck is not set to low that you are cutting dirt instead of grass also make sure that all of the rods and opins are secure and are not bent ok?
best regards mike
Posted on Aug 22, 2009
  • 5 Answers
SOURCE: How to install a drive belt on a john deere 175
Photos and description available at
http://outdoorpowerinfo.com/repairs/deere_175_drive_belt.asp
Posted on Sep 04, 2009
  • 69 Answers
SOURCE: blades wont engage on a john deer riding mower
May be a safety switch not letting the PTO engage the clutch? Also check your voltage at the battery...too low a voltage won't let the clutch engage either. Should be between 13.3-14v at full throttle.
Posted on Sep 09, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
I have a John Deere hydro 165, Kawasaki 12.5 ,what oil does it use?
Most all Engines used in warm climate such as mowers etc.. Use standard weight SAE 30 but colder climates machines such as snow blowers etc. use any good quality mili viscosity oils 10-30 is an all around one..good luck a little higher such as 10-40 for high hours used machines..good luck..
Aug 25, 2015 | John Deere Garden
John deere la 125 yard mower
missing lever retainer on deck replace it
Sep 07, 2014 | Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
John deere lx277
make sure if its a hydro drive disengage lever isnt pulled
Oct 03, 2013 | Garden
John deere mower stopped cutting
it could be a few different things it depends on if it is a electric clutch or manual for engaging the deck. It also could be a bad pulley on the deck
Jul 28, 2012 | John Deere 22HP VTwin Hydrostatic 42"...
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Does not move when in neutral and the brake is off. push forward or reverse.
hi there pauly 46 here
make sure that the hydro box bypass lever is engaged ( that is pushed in)
check that the axle /shaft keys are in place ( or unit wont move )
make sure there is tension on the drive belt and the tensioner pulley is ok and belt has not jumped off and the transmission input pulley on top off the hydro box is turning.
then check that the splines on the trans input pulley are not stripped.
then check that the input shaft splines are not stripped as well.
make sure the hydro box has got the correct amount of oil
have look and see what you can find
cheers pauly46
Apr 24, 2011 | John Deere 22HP Hydrostatic 42" Riding...
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
329 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
