When you will replace the brother unit then you will need to reset the brother dcp7030 laser printer. Follow these steps for reset the brother printer.
Press the "X" keys to drum the error message.
Select the setting.
Press the All setting.
Now press the Machine info.
Press parts life.
Press the # key until the display message on the machine changes.
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Some
Brother laser printers have separate consumables - the toner cartridge
and the drum unit. From time to time you may need to replace only the
drum unit and not the toner cartridge.
The
error LED lights up, or an error message shows on a flat screen panel,
when the drum unit is near the end of its working life. Use the drum
unit until you have a print quality problem, then replace the drum unit
with a new one.
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
