Hi There: Our machine makes a loud banging noise...as if sneakers are in the drum, during the wash and spin cycle. Opened up the door and found several plastic shavings under the gray flap. Shavings appear to be from the plastic edge. What is the problem and how do we go about fixing it?
  • niftystuff1 Oct 14, 2010
    ooops....it is a front load washer GE model #GEHW9150PWO..........Thanks
    President:
  • 670 Answers
You did not supply the make and model of the washer. But from your description, it seem like you have a front load washer. The problem you describe sound like the support arms that hold the wash drum are broken. It is a big job to fix and also an expensive one unless it is still under warranty. The wash drum and spider will need to be replaced at a minimum, if the outer wash tub is damaged, it will also need to be replaced. The wash tub is made of plastic, and it is being damaged with the wash drum scraping the insides of the tub. To repair the entire washer needs to be disassembled and the drum and tub needs to be removed. The parts and labor most likely exceed the cost of the machine. Sorry.
Posted on Oct 14, 2010
    Sergeant:
    Champion:
  • 226 Answers
The balance spring it broke
Amana top loader washing maching permanently tilted drum & loud banging during spin cycle
I guess you washed some curtains and blankets in it that it spun unbalanced. There are 2 things. One is the one of the suspension springs broke off. Another is the center post is already bent. You may have to check inside. If you are handy, you can take off the cover and check. Suspension springs are dangerous when being replaced. You may have to wear a pair of goggles. With the centerpost, it is difficult to replace. I suggest you call a technician for this.
Jan 17, 2014 | Washing Machines
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
May 02, 2013 | Washing Machines
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Banging during the wash and spin cycle
sounds like drum is out of balanced call repairman they can rebalance drum this needs to be done ,once a year.
Dec 16, 2009 | Frigidaire GLTF530DS Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
276 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
