Question about Toshiba TEC B-572 Printer
TEC 572M barcode pot stake printer is stuck with the error "Head Open" even though it is closed. We have removed and replaced the stakes and shut the power on and off and still have the error and can not get it to do anything else.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
The head open is generated when the small microswitch on the left of the print head is damaged. Either you change with a new one or shunt it.
Posted on Jan 14, 2014
4 Suggested Answers
  • 254 Answers
SOURCE: The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Posted on Sep 03, 2009
  • 24 Answers
SOURCE: How to configure internal LAN in B-SX4T barcode printer?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
Posted on Dec 17, 2010
  • 254 Answers
SOURCE: TOSHIBA TEC BSX-8T head open problem
Problem comes from two micro switches.
One on the left of the head and the second on the rollers at hte back.
Ensure that le lever at the back is up because it's in this position that it presses on the microswitch. If that is the case the your printer should turn ready.
Else open the printer an strap both switches by a bridge.
Posted on Aug 05, 2011
What are the minimum and maximum stakes I can make?
It will depend on the material from which you wish to manufacture the stakes, and the tools and equipment you use to do so.
Stakes can be so small you will need magnifying glasses to see them, to being so large they look more like telephone poles than stakes.
Please tell us which materials you wish to use, what you wish to hold with these stakes, and what tools you have to work with.
Apr 06, 2017 | The Office Equipment & Supplies
Assembly Manual
Nothing to assemble in this kit:
Product Description Universal tent assembly and repair tool kit
1 mallet with white rubber head
1 guy rope: 15 m , colour Grey/Black
1 guy rope tightener
6 adjustable fasteners for ropes: 3.8cm x 1.3cm x 0.4cm
4 round closed hook head, zinc plated steel stakes: 23cm x 3.9mm
4 standard zinc plated steel stakes: 27.5cm x 6.5mm
4 zinc plated steel stakes: 23cm x 2.0mm x 1mm
4 zinc plated steel stakes: 28cm x 2.0mm x 1mm
8 nylon/elastic rubber rings: 29cm x 0.4cm
2 self-adhesive pathces: 7.5cm x 0.55cm
Oct 30, 2013 | The Camping Equipment Company Universal...
Unable to sit more than 200/400 stakes
Je ne peux pas ouvrir poker.zynga.com sur facebook
Jul 13, 2013 | Zynga Texas HoldEm Poker
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
Where can I buy tent stakes?
Walmart have tent stakes that are reasonably priced and you can buy them individually which is really helpful. We lost just one of ours and I didn't want to replace the whole set. http://www.walmart.com/ip/COLEMAN-TENT-STAKES-10/13848624
Sep 10, 2012 | Camping, Backpacking & Hiking
I've lost the instructions for my Holiday Living #10243 6-outlet outdoor yard sake with digital easy set timer. How do I program the yard stake? thanks!
I think the Holiday Living yard stake is made by Woods.
GE sells identical 6-outlet yard stake for which I have a manual with clear instructions and images:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Add a comment to help me identify your timer so others will be helped also.
If manual shown above is incorrect, open link below to view general list of yard stakes with manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
Dec 11, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
PAPER JAM
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 05, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
How to remove heater core 2004 grand prix
The entire dash does not need to be removed.
Disconnect the heater inlet and outlet hoses which enter the firewall directly under the 'hard lines' for the AC'. near the center/driver side of the fire wall. Note: A cable operated clamp removal tool helps access. They sell them at Autozone in the 'OEM' tool section)
Remove the lower kick panels on both sides.
Remove the seats and console and carpet (to access and remove the duct which goes from the bottom of the heater core outlet cover to the back seat area)
Remove the outer heater core cover.
(Note: First time through the outer heater core cover is held on only by heat stakes, no screws. You need to break the head of each of these heat stakes (look like donuts) to remove the case.
Remove the inner heater core cover (also heat stakes).
Remove the heater core.
Installation is reverse of removal.
You'll need to drill the marked dimples next to each of the now broken heat stakes. Drill 5.5mm holes in cover in these areas and replace cover with screws which should be available from GM dealer.
Oct 05, 2009 | 2004 Pontiac Grand Prix
To find nfs game site
the game is apparently very old....
u r not gonna find the official page of the game...even EA has removed it from its official site.
this is the closest u r gonn get to any organized info about it....
http://www.mobygames.com/game/need-for-speed-high-stakes
Jan 01, 2009 | Electronic Arts Need For Speed: High...
Toshiba TEC B-572 Printer Logo
151 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
