Question about RCA HD52W59 HDTV Projection Television
LOOKS LIKE HIGHVOLTAGE WAS JUMPING ACROSS A COLD SOLDER JOINT IN THE FLYBACK VICINITY...RESOLDERED LEG AND THE TV ATTEMPS LIKE 3 TIMES TO POWER UP TO NO AVAIL?HELP!
    Genius:
  • 1,030 Answers
Sometimes when shorts or sparks occur in the viciity of the flyback. compnents take a hit. if i had this set in my shop i would first check what is called the horizontal output transistor. this transistor is directly related to flyback and i would suspect it to be shorted. certain capacitors and diodes also can short under the same situation. And theres a possiblility that the flyback is bad
Posted on Oct 14, 2010
Vertical hold (picture squashed into 100 mm wide )
This only happens on tube TV's. I am assuming that you are dealing with a flat screen tube TV, not a flat panel TV.
Your issue is that the voltage on the vertical sync is low. This can be caused by a cold solder joint, or a bad transformer.
A "cold" solder joint. Just means a solder joint with poor contact. This can happen over time, and it's pretty easy to see. The solder will look dull grey, and have a brown greasy substance on the surface. you can just heat the solder with your soldering iron to remelt it, if this is the case.
Unless you have experience with repairing tv, I can't give you any more advice, without suggesting that you do things that could hurt you.
If you are going to open the tv yourself, don't do so without leaving it unplugged for 24 hours minimum. Most tvs discharge all power when you unplug them, but not all have this safety feature, and the flyback transformer has adequate voltage to kill you.
May 08, 2011 | LG Televison & Video
It has alot of tint pruple , like 3d .
hello my is rico and i work on tvs sometimes. it looks like bad convergance but on this tv sometimes has cold solder on the power supply, on the flyback with cold solder, and pico fuse with 5amp. check your board inside your tv underneath for cold solder on the entire board, if you need more help with your tv feel free to call me at 602-810-7149 i live in mesa az
Dec 29, 2010 | JVC AV-48WP74 48" Rear Projection...
Toshiba 60 in projection tv picture goes out. the screen is black. unplugged until red light goes out, then restarted and picture comes back fine. until it happens again. 3 times in about 15 min. it...
the unit is developing whats called a "cold solder joint"...have it resoldered before it becomes a burnt out section of printed circuit board if it starts to arc...
Jul 25, 2009 | Televison & Video
Hitachi 65xwx20b
hello . it's sound like a cold solder joint on the power supply board.!!! what happen's is the set get so hot where the solder in the connection's spred a way from there connection. !!! and they need to be resoldered to make them connect again.!!! if you know how to solder you can do it your self. with on line help.!!! "GOOD LUCK"
Jul 08, 2008 | Hitachi 50UX58B 50" Rear Projection...
Convergence nightmare
If this is a ITC222 chassis then you need to check the fuses that are near the flyback. I would also unsolder all the pins on the flyback and re-solder them as the factory lead free solder tends to crack and cause issues with the convergence. Re-solder it with common 60/40 solder you can pick up from Radio Shack or other places.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Jun 08, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
My tv cant turn on
make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
1 www.partstore.com
2 www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
May 26, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Rca hd52w59 convergence problem
there is a special fuse on the power deflection board. when blown this causes the processor to think it a crt tv. The fuse calle fl231 is a small brown rectangular fuse in the middle of 3 just like it next to the flyback transformer the big black thing with the large red wire comeing out. ussally it blows because the solder connections on the flyback. WARNING high voltages are generated by flyback. be careful please
Dec 27, 2007 | RCA HD52W59 HDTV Projection Television
JVC 31" TV Vertical Screen Jumping
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Sep 20, 2007 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
