Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Dead set after lighting
I am looking for someplace to order parts
  • Protron Master
  • 5,568 Answers
Posting this for the 4th time on this brand:
 I checked and found the Protron name belong(s) or (ed) to Spectroniq and neither of the two websites are up anymore.
Also, I could probably make a zapped supply work again but you do not know what might have been damaged downstream from it and that is a good possibility; the damage may be much deeper than it appears since many of the integrated circuits used in modern equipment don't tolerate hundred (or thousand) volt spikes and without a working supply, there is little chance of diagnosing it unless a service department has a few lab-type power supplies and can simulate the failed original supply.
If you do find anyone who has stock on assemblies for this TV, you may find more than one part number on the board. If it is a number that seems to be under clear lacquer, it is likely only the bare board number. If it seems to be stamped on or has a label with a number on it, this is going to be the whole part number for the 'stuffed' board.
I can't help you with this one but I would suggest, especially if you live in a lightning-prone area to consider installing a 'whole house' surge protector. They do cost a couple of hundred US dollars plus installation charges, but the established companies even include an insurance policy that covers $10,000-25,000 in damages. If you own your home, it's your decision and I cannot imagine any landlord would object to having you install one at your own expense.
Posted on Sep 28, 2008
2003 Jimmy 4.3 Battery drained down every few days and had to be charged. Today the battery was dead. Replaced it.
check charging rate on new battery with engine running, should be 13.7 +.
if not, check alternator.
if alternator checks out, may be a drain somewhere, light on someplace, etc.
Oct 06, 2015 | GMC Jimmy Cars & Trucks
What causes my vehicle to shut off at a light
have the OBD codes read as will tell you which sensor/switch is causing the problem
Jun 23, 2014 | 2002 Pontiac Grand Am
Mitsubishi 73733 DLP Completely Dead, No Power, No Lights
Hi we had the same problem after a storm, the tv shut off - no sounds no lights - had a tech come out to check the tv and he told me that the main/motherboard had been struck by lighting (I figured that part), so that gave me a starting point...he wanted to charge over $600. Soooo I searched and found the part on ebay and ordered it thru tvbservice it cost us $200 and we put it in ourself. (p/n 934C260002) It wasnt hard to do at all, just alot of screws lol. The end result was that...THE TUBE IS BACK UP AND RUNNING!!!! Hope this helps!
Jul 30, 2012 | Mitsubishi WD-73733 73" HDTV
1988 delta 88 ,won't crank over, no dash oil, temp ,check engine lites etc, heater fan all dead. Headlights , dome and dash lights,radio work. Battery is good, starter cranks if cross terminals on soleniod...
the car gets power from the fusible links on the starter. or the fuse box. follow the positive cable if it splits into 2 directions, follow the small lead and inspect any fuses you find.
Dec 11, 2010 | 1988 Oldsmobile Delta 88
Polaroid FLM-3232, red power light, then blue power light.
You need a main module----Part #909-kso-gf321xa Encompass
List price is $462.00
Craig----Hi-Tec Electronics
Apr 18, 2009 | Polaroid FLM-3232 Television
Dead, green light flashes only.
Replace the digital pcb. It comes it two parts so make sure you get the one on the top.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Acer acernote 735c memory 8mb 40pin DRAM SIMM
Try this site for older memory types
Jan 25, 2007 | AcerNote Light 355 PC Notebook
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
49 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
