Question about Mitsubishi Televison & Video
When I turn on my 65" the message displayed reads the air flow is blocked and the tv will shut down which it does. I've vacumed & cleared all openings. I have to reset the tv about (5) times before the message won't come up and it runs fine until the next time I turn it on. What is the cause?
    Genius:
  • 1,030 Answers
Ok what you have there is a faulty thernal sensor nitisubishi has issued a bulliten to serice centers so check with local service center the repair might be covered under warennty
Posted on Oct 14, 2010
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
I get a message that the air flow/fan is blocked, then the tv shuts down. It's not blocked. It's perfectly clean.
This indicates the TV is overheating. Lamp based TVs usually have two or even three fans. One may be having problems or not turning fast enough.
Mar 31, 2010 | Televison & Video
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
Error Message
If the set is only 3 1/2 months old, you should still have warranty coverage. Opening up the unit will void the warranty, so don't open up the set. Call for warranty service. In all probability, the air flow sensor is defective. The message you are seeing is a result of the air flow not being detected or not sufficient. In any case, this is a covered problem and should cost you nothing to fix.
Dan
Mar 20, 2009 | Mitsubishi WD-Y65 65" HDTV
Mitsubushi 1080 HDTV has an air flow block
There is a fan in the back. Make sure that the fan is spinning and that the grille is clean. It is possible that the sensor is bad too.
Keep us posted.
Dan
Jun 06, 2008 | Televison & Video
Mitsubishi 65" 1080p DLP Projection HDTV (WD-Y65)
have you cleaned the air filter located on the side of the set? If that doesnt work the thermal sensor will need replacing.
Apr 24, 2008 | Televison & Video
Mitsubishi WD-65731
Here is a link to what models have a recall for a faulty sensor... extended warranty on that part preplaceable for free by MDEA.
http://www.mitsubishi-tv.com/j/i/18312/Warranties.html?mid=125121
Nov 02, 2007 | Mitsubishi WD-65731 65" HDTV
Televison & Video Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
