Question about Acer ScanPrisa 640P Flatbed Scanner
My scanner has a parallel port and my notebook has only usb port. Can I purchase an adapter to convert the parallel port to work with the usb port?
    President:
  • 261 Answers
HI
yes there is but not compatible with all devices
good luck
Posted on Oct 14, 2010
No parallel port on my computer. USB -parallel
This scanner is an old one so it has only parallel port. You can connect it to any USB with the converter you mentioned and should be working. Did you connect the power supply at the scanner too? It is nesessary for the scanner in order to take power.
Stelios.
Feb 22, 2010 | Canon CanoScan N640P Flatbed Scanner
Can the P2055d be connected with a parallel lead?
Most HP's if they have a port for parallel, it is a special plug on the back that looks more like a SCSI plug. If your printer has this plug you need the special cable, otherwise you will need an adapter to convert USB to parallel.
Dec 28, 2009 | HP LaserJet P2055d Printer
Packard bell scanner driver this is an old scanner but unused. Is there any compatible software or drivers that allow its use on XP or vista.
Hi:
If your scanner is a parallel port scanner, and not a USB type, then it is very difficult to set up on Windows XP or newer. There are some USB adapters that convert a parallel port , but usually only good for printers, and not scanners.
Nov 03, 2009 | Office Equipment & Supplies
Connecting old IBM color flatbed scanner to new computer
Not likely to work reliably if you get it to work.
The parallel port must be set to communicate in both directions. The SUB to Parallel adapter may be a ONE-WAY communications device.
Get a new (or used) Epson scanner or Epson all-in-one ($50) which includes a scanner and printer! Your new computer may not have the proper drivers for your old IBM scanner, anyway. If you purchase an Epson all-in-one, get a "WorkForce" model - that's their latest product line.
Sep 28, 2009 | IBM Color Scanner Flatbed Scanner
Acer scanprisa 640p paralel to usb port problem
Push the parallel end of the cable adapter onto the parallel port of the printer. ... Ensure that the clips for the parallel port and cable are in the locked positions. 3. Unplug the USB end of the cable from the USB port on the computer, and then reinsert it.
Also look here-
https://yourbusiness.azcentral.com/use-parallel-scanner-usb-7712.html
Jan 06, 2018 | Acer ScanPrisa 640P Flatbed Scanner
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
No port for printer connection
It has usb ports... if your printer is Parallel you should purchase a parallel to usb adapter.
here is an example of an ebay auction for one...
http://cgi.ebay.com/USB-to-PARALLEL-PRINTER-ADAPTER-1284-CABLE-36-PIN-IEEE_W0QQitemZ250463737409QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item3a50cd5641&_trksid=p3286.c0.m14
They are cheap
Hope this helps.. remember if the cable is not long enough on the adapter you can always buy a usb extender.
Apr 12, 2009 | Compaq Presario S200
Unable to use CanoScan N640P with Acer Notebook
Hi ymonique,
Can you tell us whether this worked? I have the same problem but the system still cannot find the scanner when I use a USB to parallel cable.
Sep 29, 2007 | Canon CanoScan N340P Flatbed Scanner
Parallel port
I found a couple of adapters that might work. http://www.shopping.com/xPO-Sabrent-Sabrent-USB-to-DB25-Female-Parallel-Converter-Adapter-6ft-Cable http://www.newegg.com/Product/Product.aspx?Item=N82E16812156012
Jul 12, 2007 | Tamarack ArtiScan 2400FS Film Scanner
Acer ScanPrisa 640P Flatbed Scanner Logo
160 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
