Question about Seiko Instruments Smart Label Printer 420 Thermal
I print a label and when it ejects, it ejects 1/2 of the next label. It doesn't stop at the perforation. What do I do?
    President:
  • 261 Answers
Hi
check your software (the file that you print)
its may be you have a blank space in your file
otherwise turn to your printer adjustment
Posted on Oct 14, 2010
How can i adjust the label feed
Firstly the length of the label must be correctly set.
- When activation forward wait on parameter, you can adjust the feed value.
- else you can adjust the feed value in the driver.
Feb 07, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Print dosent stop
u have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Jun 25, 2013 | Zebra Eltron TLP 2844 Thermal Label...
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
My lp2844 keeps printing part of the job on one label and the rest on the next. It seems like it starts the print job in the middle of the label and prints across ther perforation and onto the next label,...
sounds like you have the printer driver set to the wrong paper size
unfortunately some of these drivers disregard the settings you do in windows and so you need to set it twice , once in the windows printer dialog and second in the configuration wizard of the driver
hth hannes
Aug 29, 2009 | Zebra LP 2844 Thermal Printer
How can I fix this problem?
My printer is only a few months old. I have used up all the label roll that came with the machine and have put in a new roll (99010) which is slightly slimmer than the original one. I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label). HELP!
Aug 05, 2008 | Dymo LabelWriter 400 Thermal Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
Seiko Instruments Smart Label Printer 420 Thermal Logo
282 people viewed this question
Top Seiko Instruments Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Seiko Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
