Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
Hi my name is Debbie and I 'm having problems with my Jazzy it was working fine, I took it out and when I got home I plugged it up for recharging, now it doesent want to do anything all of a sudden it dont want to work the lights flash off and on why is that
    Novelist:
    Champion:
  • 232 Answers
The number of lights that are flashing can indicate what the problem is; Visit this site to determine the type on controller on your power chair to know what the lights mean:http://www.pgdt.com/scenter/diagnostics/diagvsi.html
You can also refer to your owner's guide for troubleshooting, or contact Pride to see if they can troubleshoot over the phone.
Posted on Oct 20, 2010
  • 692 Answers
Debbie it might be in sleep mode to restart push the on/off button twice. If that doesn't work try turning the unit on immediately push the joystick full forward and hold till you hear a beep then immediately push the joystick fully back until you hear another beep then release the joystick to the center position. If the chair was in lockout this should release it tun the chair off then back on and it should operate normally. If you still get the error contact your provider for help Hope this helps
Posted on Oct 18, 2010
Pride Jazzy 1103 Ultra: Bought used and came with new batteries. Worked fine until a week or so ago. Then died and couldn't be recharged (on-board charger). The seller kindly sent an external
a cheep fix is the charger I am showing you from Advance auto it will bolt into stock location and bolt to battery post you will need to make a jumper wire to send batt. voltage to joy stick controller well worth doing the modification to save big $$$$.
Dec 20, 2014 | Pride Jazzy 1103 Ultra Standard Power...
My jazzy 1113 won,t come out of slow modeI have reset it it jerks herky jerky tries to set into reg mode then slips with a **** back to slow hellp it took me an hour to get home and it was onlyh 10...
Hi.Sounds like faulty motors to me. Check brushes and brake units. How much work has the machine done.
These motors develope a build up of carbon and copper dust from the brushes and commutator. This dust can cause a partial short from the armature to the outer casing of the motors. What happens then is the signal from one motor leaks through to the other motor causing the controller to think its developed a fault. A good serviceman can tell you if this is the case. Good luck. Neil.
Feb 20, 2010 | Pride Mobility Products Jazzy 1113 ATS
My jazzy 1115 joystick controller flashing and the chair doesnot move .
1. make sure it's not still pluged in recharging.
2. make sure both free wheel levers are engaged.
if the jazzy is still flashing and not moving refer to the flash code in your owners manual. count the flashes between pauses. get back to me if you don't have the manual. Mike
smithrm70@hotmail.com
Nov 20, 2009 | Electric Jazzy 1115 Power Wheelchair
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
Nov 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
I have a Jazzy 1121,when I went to plug it in to recharge it, I noticed the lights weren't flashing like they suppose to and plus while it was plugged in I was still able to move the chair, when I...
The chair is not recognizing the charger. If it is an off board charger, check the pins in the conncector to be sure that one has not been pushed back. On board, check to see if the amp meter moves at all.
Oct 04, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Can't log onto Windows XP
Let me guess you type in your password and user name it then logs off. Have you check the recharger it may not be you laptop but the power plug not connecting there for you laptop had ran out of battery. Check recharger as I had the same problem and I replaced the plug recharger and it worked fine.
Jan 11, 2009 | Microsoft Windows Services For NetWare 5.0...
Hi, i have a problem with my toshiba regza, 32" about 18 months old, keeps changing screen width to 4:3 from widescreen on some of the music channels on sky! keep resetting it but still does it next...
Hi Debbie,
Check the picture format setting on your Sky box.
Press Services.
4 for set up.
1 for Picture.
Theres and option that says 16:9, 4:3 or 4:3LB, make sure its set to 16:9.
Then go to Save settings and press the Select button to save the setting.
Regards
Andy
Jun 26, 2008 | Toshiba Televison & Video
Computer will not power at home ok at friend home
ether the power supply is bad or your outlet is not grounded
Mar 27, 2008 | Compaq Presario 5000 PC Desktop
My GPX PDL 805 will not function on the battery-
Hi Eileen,
Heat can kill a dead rechargeable battery. You can get batteries on Ebay. You just need to know the number off the label.
Nov 28, 2007 | GPX PDL805 Portable DVD Player
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
178 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
