Question about Brother HL-2040 Laser Printer
My drum light is flushing - Brother HL-2040 Laser Printer
  • 4 Answers
Open front door where toner/drum goes in
Hold GO button down for about 5 seconds
All lights should come on then go out when GO button is released
Shut door and wait for warm up to end
Drum light should no longer be flashing
If still flashing then try procedure again
Posted on Oct 18, 2010
    Sniper:
  • 53 Answers
The light means (acording to Brother.com) that the drum will need to be replaced soon. It is available for purchase online through Office Depot, Office Max, Best Buy, etc. for about $120 U.S.
Check out the user manual in PDF format on the Brother website. The pertinent info is on page 46 of the PDF (Control Panel section, page 3). See link below:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2040_2070N_EN_1289.PDF
Posted on Oct 14, 2010
My drum light was BLINKING then I took out everything and shook it a little. Now the drum light is SOLID ON and won't print anything.
How to physically reset the thing so the light stays off? How to clean the drum if needed?
Posted on May 01, 2011
Brake pull when applyed
go back to the people that did that work and holler loudly it was not fixya was it ?
Feb 12, 2015 | Galaxie Conquest 1964 Ford Galaxie 500...
Our Model WM2487H*M detergent box fills with water as the washer is working. We are using Tide pods in the drum.
The detergent dispenser is flushed with water during the wash cycle to remove residue. The flushing occurs automatically regardless of the type of detergent used, liquid, powder, or pods.
Jan 19, 2015 | LG Washing Machines
Rear drum brakes making clunking sound when braking
Recheck your work
Did you install new springs?
Flush/Bleed the System?
Turn the Drums?
New Wheel Cylinders?
Jan 06, 2013 | 2002 Chevrolet Cavalier
The lights keep flushing, does not want to start
Hello joanna-telec - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Also try to rotate the drum manually (when it is not in use) and see if you notice a bumping sound as well. If you do, then the drum is not balanced and probably the bearing and pulley system behind the drum will need repairing. Other possibilities could be are a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Nov 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
The washing machine won't drain water? how can I fix it? Its seems clogged with debris
Ideally you need to remove the pump and outflow pipes and flush them out. Also check the pipe between the drum and pump for a blockage. Back flush the outlet pipe from your hot water tap..
Jan 28, 2011 | Whirlpool LHW0050PQ Front Load Washer
I have a Riso RP 3700 and I changed a drum from brown ink to yellow ink and I can't get the brown ink to clear away, no matter how many sheets I run thru with yellow ink.
I've read a little about flushing drums with solvent or even gasoline or diesel google it a little see how people have done it. though I can imagine a Switch from a dark to light colour might be impossible. You could pull the screen off and wash it out. Some ideas. No solutions.
Jan 12, 2011 | Riso RZ220 Duplicator
Noisy bearings
ok, turn the nut at the back anti clockwise, i normally jam the pully into the cut outs in the drum, when you have taken off the nut hold the inner drum inside the outer drum and tap he pu;;y anti clockwise, not too hard or it will crack, remove pully, place nut flush with shaft on the thread and you will be ablt to tap the drum out without damaging the thread.
Apr 07, 2010 | Washing Machines
Brother HL-2040 Laser Printer Logo
771 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
