Question about PfaFF Creative 7570
Thread bunching underneath fabric as I sew.
I have tried to adjust the bobbin tension to no avail. The machine was sewing just fine then started to bunch underneath. The lower tension is obviously the problem. I re-threaded, cleaned and changed the needle. I hadn't used the machine often when this started to occur. The last thing I sewed on it was polar fleece but I was always careful to clean the machine after use. I haven't been able to use this Pfaff for years. I really need my machine back. I am hours from the nearest Pfaff dealer and as a single Mum I am too broke to pay for the service/repairs. If anyone has any suggestions, for home repair, I would appreciate them.
  • criket Nov 30, 2008
    our machine has just been serviced and was even given a sample of different setting used. we tried sewing and still bunching!!!
You may need to take off the housing that covers the whole dog mechanism. You will need a screwdriver to do this. Blow out the area around the tension gears and dogs, check for loose or disconnedted parts, and re-oil the gears. Fleece fuzz usually collects where you can't see it. This was the problem with my machine that had the same symptom.
Posted on Jun 03, 2008
Thread is loose and bunching underneath. I've tried adjusting tension but no changes
could be the bobbin case also needs adjusted for tension .
Oct 15, 2016 | Sewing Machines
Top thread is bunching underneath
bunching underneath is an indication that the top tension is incorrect
switching projects and materials also that attention has to be given to tension adjustment both bottom and top
the catching sometimes indicates that a tension is too tight and is pulling the needle out of line
Jul 25, 2015 | Sewing Machines
It just started sewing upside down it was fine earlier, I have just rewound the bobbin
1. You will likely need to adjust the bobbin tension. Make sure that you have placed the thread under the tension spring to start with.
2. If it is bunching up on the bottom your tension on the bottom is too strong. Before you do anything you can increase the top tension to offset this so you won't need to mess with the bobbin if it isn't a great amount.
3. JUST FOR INFORMATION: When you change threads they are either thicker, thinner or the same. This will require most of the times to adjust the bobbin.
SEE BOBBIN ADJUST:
Jul 14, 2015 | Singer One Plus Computerized Sewing...
I have a Bernina 1008. The thread is bunching up underneath when sewing. I've cleaned and oiled the bobbin area, rethreaded and adujusted the upper tensnion- the topstitch looks fine, it's lumpy on the...
Hello. Make sure the bobbin is not backward. It seems the upper tension is still not adjusted right. If the bobbin pulls smooth focus on the top tension. Good Luck
Feb 13, 2014 | Bernina 1008
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Jun 15, 2009 | Husqvarna Viking 1
Thread bunching on model singer 2157C
According to everything I've researched, when this happens it's because there is no tension. Check & make sure it's threaded properly. If it's still bunching underneath, then there may be something wrong inside the machine - even though you adjust the tension, it may not really be happening inside. You'll have to take it apart or service it.
Aug 29, 2008 | Singer 2517 Mechanical Sewing Machine
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
302 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
