Question about Canon Cameras
I have a A1000 15 Canon , I had about 300 photos on the memory card, the setting was at normal and some one changed the setting to fine and now it shows no images on the memory card.. Are they deleted ?? Or is there a way I can still find them? Linda
    Brigadier General:
  • 11,967 Answers
They are probably still there but in a different folder. If you use a card reader to download to the computer, you will see them.
Posted on Oct 14, 2010
How do I upload my most recent photos from my Canon Power Shot A 3100 from a memory card that has at least 300 pictures on it without uploading all of them?
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 31, 2012 | Cameras
I have bought a Canon MP510 printer/scanner. I cannot figure how to change the photo size settings in Memory card mode to 6x4. I change it then save settings but always reverts back to a factory setting 11...
All you need to do is to change the size in the software which you are using to edit the photos and do a save changes before you close the application,
Apr 20, 2008 | Office Equipment & Supplies
What setting should i have the camera on for normal photos, I have a 32 memory card, however after 10 photo's the camera tells me that the memory card is full.
A 32mb card is very small. If you are shooting at the full 8 megapixels, that's why your card is getting full. You should have at least a 1gb card.
Sep 10, 2010 | Canon PowerShot A580 Digital Camera
My camera says my memory card is locked but the button on the side is not locked how do i retrieve my pictures i have a canon powershot a480
Issue: [Memory card locked] message appears on the screen.
Solution: Change the memory card lock switch to the normal setting
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Please remove the card from the camera and ensure that the switch is not in the locked position. sdcardlocked.jpg
sdcardunlocked.jpg ---
You should be able to retrieve photos, but not writing or erasing if the switch is switched to write protect.
If it's not functioning correctly, the camera may need service at Canonusa.com.
Jun 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Photo storage?
It depends on the picture resolution and the size of the memory card.
Normal JPEG 2048 x 1472 : 11.0 - With 16MB built-in memory , Fine JPEG 2496 x 2016 : 19.0 - With 16MB built-in memory , Normal JPEG 2048 x 1376 : 19.0 - With 16MB built-in memory , Fine JPEG 2496 x 2016 : 9.0 - With 16MB built-in memory , Normal JPEG 2048 x 1472 : 9.0 - With 16MB built-in memory , Normal JPEG 2048 x 1376 : 35.0 - With 16MB built-in memory , Fine JPEG 1024 x 736 , Fine JPEG 1024 x 736
The capacity of various memory cards will be similar to the above ratios.
I hope this helps.
Jul 04, 2010 | Vivitar ViviCam 3765 Digital Camera
I have a canon a470 ps i installed an canon sdc-32m card in it but still its captures only 12/13images...?
OK OK i understand . go setting in camera & save change the photo storage device in your memory card. i am 100 % sure right now all photos are save in your camera internal memory. just transfer it in memory card .
Jan 30, 2010 | Canon PowerShot A470 Digital Camera
Memory card error - After taking about 300 pictures on a 2 Gig Kodak SD memory card. I get a message on my Canon camera that says '' memory card error'' I tried to put the chip in a differant camera but it...
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're inexpensive.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but the file structure will eventually corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again. Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Nov 16, 2009 | Canon Cameras
Black images on the screen
There will be manufacture defect in the lens so you need to get the replacement of it as you will be having the warranty as it is a brand new...
Regards
-Dileep
Jan 24, 2009 | Canon EOS 40D Digital Camera
How do I adjust the resolution that the photos are saved?
To change the resolution and compression:
1. Press the Func button.
2. Scroll down, if necessary, to the icon in the lower left corner of the LCD.
3. Use the right or left arrows to select L (large), M1, M2 (medium), or S (small). Press the Set button.
4. Use the right or left arrows to select superfine (quadrant with S), fine (quadrant), or normal (stairsteps). Press the Set button.
5. Press the Func button to exit.
Large/superfine images will take up the most space on the memory card. Small/normal images will take the least, but the picture quality will be less if you're printing the pictures.
There is a table at this link (scroll down) to show you how many images will fit on a memory card at different settings.
May 09, 2008 | Canon PowerShot S1 IS Digital Camera
Canon A540 or SD card problem
Hi Rich, This sounds like a problem with filing system of the memory card and is indicative of forthcoming bigger problems. Try remove from the camera and slip into a memory card reader attached to a PC. You have to try and recover as much photos as you can. Thereafter, it may be required to format the memory card either via PC or the format command in the set-up/menu of the camera. Further you can use diagnostic utilities (PC side) to determine if the memory has developed any bad areas. Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Canon PowerShot A540 Digital Camera
Cameras Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
