Question about Amana ACD2232HR Side by Side Refrigerator
Water and Ice maker problems
About two weeks ago my ice maker started to make hollow ice cubes frozen on the outside and air on the inside. Since then I have noticed a delay in the water dispenser throught the door. I push the glass againts the leaver and there is a 2-3 second delay before the water dispenses. Now no water is going to the ice maker and it is therefore not producing any ice. The pressure from the water dispenser is the same as it has always been (good) but it now has the delay. Any thoughts? Thank you for your help
  • justing Jun 02, 2008
    The lines are copper and there are no kinks.
    Any other thoughts? Thank you
  • 45 Answers
Only other option i could think of, there is either a clog, or it's not getting the water to the ice dispenser.
possibility of a leak but since you haven't mentioned anything about excessive water on the floor i surmise thats not it.
is the motor still working properly as well?
Posted on Jun 02, 2008
    Habit-Forming:
  • 111 Answers
Sounds like you water lines may be kinked or clogged.
follow you water lines and see if there is a kink in the line that would be the easiest thing to check first.
2 Suggested Answers
  • 8 Answers
SOURCE: Amana SBS Water and Ice maker issues
The water solenoid on the back of the refrigerator at the bottom is becoming clogged. There is only a very small hole in the diaphram of the valve. I suspect you have very hard water, or at least a fair amount of sediment in the water.
This valve will most likely need to be replaced by a qualified technician.
They sometimes can be cleaned, but it doesn't always work.
Posted on Jun 10, 2008
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
My ice maker is frosting up. Why is this and what can I do?
There can be a number of reasons from an unlevel icemaker (I like to adjust to lean a little towards the wall or backside) to high water pressure, bad fill tube, or low water pressure (low fill).
The most common is making hollow cubes that break open and the water freezes up the rest of the cubes in the bin. In that case you will have lots of shards or hollow cubes.
This is caused most often by a low fill but can be because of a bad icemaker thermostat.
The thermostat is located in the front end and most icemakers fill starting in the rear. If it is not filling all the way to the front where the thermostat is located it cycles before the cubes are fully frozen putting water in the bin that settles in the bottom.
That is most often due to a tap valve or icemaker outlet faucet that is getting plugged up.
Turn it off and after the cubes are frozen check to make sure it is filling all the way to the head end where the motor is located. You should have ice in all the sections.
But if otherwise,
Usually when that happens it means you have an air leak in your ice door flapper, get a flashlight and shine it down in the ice maker chute, if you see light on the other light, you will need a new ice dispenser door.
Hope this helpout.....
Aug 01, 2010 | Whirlpool Refrigerators
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Jun 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana ACD2232HR Side by Side Refrigerator Logo
177 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
