Question about Aiwa F2000 20" TV
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to around 16. Muting is possible on setting the volume level to zero. Balance is also not working. Selecting only the right or the left speaker by using the balance control does not mute out the other speaker and there is audio output from both speakers. On setting the audio balance at the centre, the right speaker is much more louder that the left speaker. 3. Also the audio output sounds like mono though output comes from both the speakers. 4. Video is Ok.Remote control is also ok. I can understand basic circuitry but trouble shooting has become a problem for me under the instant case. Please help
    Top Expert:
  • Aiwa Master
  • 75,462 Answers
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Posted on Oct 15, 2010
  • marcusangami Jan 12, 2011
    Thanks for your reply.
    I checked for dry and loose soldering, loose contact, broken pcb tracks, loose wire and sockets, but all seem to be intact. I would be glad if you could kindly help me further.
I have a Kenwood KR-V9030 and the right channel is crackling and will not provide increased output when the volume is turned up. 1) Swaped speakers from left to right and the problem is in left speakers...
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Apr 16, 2011 | Audio Players & Recorders
Aiwa 8100 amplifier, low output on left hand channel, need to turn balance control way to left.
Aiwa xx8100??? What are the missing letters? Maybe it's a source or preamp problem, eh?
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
Apr 09, 2011 | Audio Players & Recorders
No problems for serval years. Right sound output died on both speaker and headphones, very slight buzz on increasing volume. Left sound output okay. Suggestions please. Jim Conway jmrc@aol.com
Feb 21, 2011 | Nakamichi AV-2 Receiver
How do i connect a aiwa 2.0 speakers to philips dvd player?
In general, speakers don't connect directly to a DVD player (model unknown) as DVD players generally have no way of amplifying a signal to speaker level.
Assuming the speakers were self-powered, you would not be able to control the volume since DVD players generally have no output controls.
I have found nothing online that matches "aiwa 2.0" as a unique speaker model.
Can you re-describe the speakers and the DVD player piece?
Feb 12, 2011 | Audio Players & Recorders
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Aiwa Colour Television Model TV-SX2150 KE - Audio Problem
i can solve ur prob by your self but u have to pay for that.
Apr 01, 2009 | Aiwa F2000 20" TV
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
Low audio through tv speakers
It sounds like a connection or signal level problem, your audio system may have a greater sensitivity than your TV, has the DVD got an output volume level to adjust, some do via their remote control also some TV's have independent volume levels for their inputs within menu settings.
Looks to be phono audio so if its none of the above then you will need a small audio pre-amplifier to increase the signal level, though for my thoughts this might produce a buzz problem because an amplifier might pick up stray noises from the TV or DVD.
Amazon or ebay may help there for small units, in a metal box is best for screening, it would not require a massive pre-amp with high gain, a battery type would need to be powered by AA types for long working periods if you go that route as a PP3 will fail over extended working time.
Hope this helps........
Jan 18, 2018 | Toshiba SD-2700 DVD Player
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
Aiwa F2000 20" TV Logo
146 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
