Question about Car Audio & Video
I need a copy of the 1984 nissan 720 stereo wiring diagram
SOURCE: need stereo wiring diagram
i need speaker wire colors for a 1988 mercedes benz 300sel
Posted on Dec 19, 2007
keemo68
  • 1263 Answers
SOURCE: WIRING DIAGRAM FOR 1984 AMC EAGLE
well you have several options you can go to a dealship and have them copy the diagram for you(i do this all the time) or you can purchase a repair manual at Napa or Oreilly's for around 20 bucks. it has diagrams and schematics in it. it also has alot of instructions in it so you can do repairs yourself. By the way i'm surprised that the mechanic doesn't have these diagrams himself. I was wandering why it won't start after you changed the plugs and wires could it be that maybe the firing order is wrong. i've done that myself a time or 2. double check the the plug wires to make sure they are in the right spot. if the problem is it won't crank. chances are you have a loose ground. please rate this..thanks
Posted on Sep 05, 2008
johnny5846
  • 379 Answers
SOURCE: I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Posted on Jan 10, 2009
emissionwiz
  • 80637 Answers
SOURCE: stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Posted on Mar 25, 2009
SOURCE: Need wiring diagram of connectors for Clarion
you can usually go to the site and put in the model # and request owners manual. it is in there but you need to have adobe reader.
Posted on May 09, 2009
Need Diagram of firing order foe 1984 nissan pickup 720
Here's a link Samson to your firing order. Need Diagram of firing order for 1984 nissan pickup 720 Google Search Ihave a 85 Nissan 720 4x4 with the 2.4 engine,I have put a weber carb in mine,here's a video to see. 85 Nissan 720 4x4 2 4 Weber conversion If you want to join a cool Nissan site,here's a link,type in 720world.com,I am a member,
Apr 22, 2015 | 1984 Nissan Pickup
WHICH TERMINALS DO THE EXHAUST IGNITION WIRES GO ON TH DISTRIBUTOR CAP OF A 1984 NISSAN PICKUP WITH EIGHT PLUGS
Hi Collin,see my silver 85 nissan 720 4x4 2.4,just replaced my plugs and ngk wires, on your distributor cap,it has the marks,i1,i2,i3.i4,e1,e2,e3,e4,and the 2 coils in center,from the front of vehicle,they are 1234,order of cylinder.Here is my video.To join a cool nissan site,go to 720world.com,it's free,look me up,Tommy Perkins,check out my page and pictures.
Nov 26, 2013 | 1984 Nissan Pickup
Looking for wiring diagram for a 1984 nissan datsun pickup extended cab
I need an image of the timing distributor fire wiring of a 1984 nissan datsun.
Jan 25, 2011 | 1984 Nissan Pickup
Need wiring system diagram for nissan datsun ute 1984 diesel 2.0 litre 720
youll probably need to get a repair manual online or check with garages that have been around for a long time they may have the old ones still
Dec 01, 2010 | Datsun 720 Cars & Trucks
1984 Nissan 720 4x4 starts fine but runs rich, misses, sputters. New distributor, plugs, wires, cleaned fuel tank.
check pvc and check for air leaks around intake and carb gasket use a little carb cleaner if engine sputters while spraying u have a leak
Aug 09, 2010 | 1984 Nissan Pickup
Vaccum hoses are missing. 1986 Nissan 720 4X4
truck normally has a vacuum hose routing diagram on under side of hood on drivers side.also look for metal tag on center of engine compartment fire wall which gives you a motor id @ and trk model # you can then know what engine vacuum diagram you need.i have a diagram for an 86 720 series Z24 carb engine that can be copied off of truck..chris
Apr 02, 2009 | 1986 Nissan Pickup 4WD 1986
Stereo wire diagram
Mar 25, 2009 | 1995 Nissan Sentra
Car Audio & Video Logo
269 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
