Question about Craftsman Garden
I have a 22.0 HP 50 in. automatic mower tractor mod.917.273100 with only 150 hrs operating time, but it's 4 or 5 years old. The nearest Sears shop is in another town quite far away from here, matter which makes me do most of the maintenance myself. The main transmission belt started slipping, I checked it and it was nearly breaking apart. I bought a new one (part #140218) and had a local mechanic install it. He found that the transaxle pulley is not moving freely, causes a lot of noise, and impedes the tractor for developing enough power; he assumed that the bearing must have failed. If he is right, that could have caused the problem. Could you please tell me if the pulley (part#140488) is actually supposed to move freely and if he could be right? Thank you, Sergio R. Lorenzo, Edinburg, Texas
  • srl1856 Oct 14, 2010
    Thanks a lot for your quick reply. I attempted to order the transaxle pulley through the Sears website, but found out that the part (#140488) has been discontinued and there is no substitute for it. This is quite strange for a tractor that is not that old. Do you have any suggestion?
    Sergio Lorenzo
  • 760 Answers
I believe your model is a hydrostatic drive. If so it would just have low-high, instead of different "gears". If there is just resistance to turning, and not binding that might not be so serious you'd be feeling the resistance of the oil pump. If there is a grinding, that could be. Here is a link to a manual for your tractor. http://www.managemylife.com/mmh/owner_manuals/22925/CRAFTSMAN-Lawn-Tractor-L0010518?brand_name_search=917273100+CRAFTSMAN
Follow directions for purging transmission. Sometimes moisture can accumulate and force oil out leaving an oil water mix behind that doesn't work. Most don't have drain plugs, but if yours does you could also change the oil
Posted on Oct 15, 2010
  • 22,326 Answers
Yes he is totally correct ,what i do with anything and everything is a the old fashioned oil can with some engine oil in it ,if you oiled everything everytime you use it then you will find it will last for ever .when he fits this bearing for you ask if their is any way he can fit a grease nipple or a hole that you can drop a drip or two of oil into it .
Posted on Oct 14, 2010
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Will a snowblower attachment model number 842-240743 fit on my riding mower
i have a snow blower attachment mod# 842.240530 sears and a sears 18 hp tractor mod # 917.258492 with no instructions on how to install them together? i dont know where all the parts go.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna iz4817 change oil light needs to be reset
The oil change reminder will flash at 49 hrs for 2 hrs then reset itself. It will do this every 50 hrs.
Jun 30, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
The cable broke which engages my blades on my craftsman 17 .5 hp 42 inch. I need a model part number for the same . I have lost my owners manual with that information
locate mod # on tractor may be under seat
go to sears.com click on parts direct and enter that number and it will take you to the parts section for that mower.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My ys4500 doesn't cut level its only 1 1/2 years old
have you checked the tire pressure? mine did this once and it ended up being a low tire.
May 19, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
484 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
