Question about Tappan Microwave Ovens
The oven comes on and the revolve plate goes around but we get no heat. Also the clock lights up but does not work.
  • Tappan Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ...
Posted on Oct 14, 2010
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
My microwave oven turntable will not rotate. How should I solve the problem? Also if I just leave it and carry on using it does it matter? Model MICROMAT 21T-W
It is rather important having a turntable that revolves. Just as a matter of interest, place a refridgerated jelly in the microwave and watch as heat is only applied at one point!
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | Microwave Ovens
Hi , in ur panasonic microwave glass tray is not revolving plz suggest what to do? thanks
Hope this helps.
Nov 04, 2010 | Panasonic Microwave Ovens
Not heating or defrosting although light works, timer etc works
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
The revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Feb 24, 2010 | Microwave Ovens
My microwave has stopped working. The first light
The megatron tube is out of this machine which is what causes it to heat. Replace machine.
Nov 06, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Will not heat
Is this a microwave you are talking about? If the clock and timer works, the light comes on and the tray revolves, but it doesn't cook food or heat stuff up, it is most likely the magnetron. Probably best to just buy another, as the cost of repairs not worth it.
Aug 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light comes on, trun table revolves, does not heat
the magnetron might be defective, also check the door interlock switches, they cause a variety of problems.
Jun 28, 2009 | LG LRM1250 Microwave Oven
Problem with hinari lifestyle microwave
you will get any Hinari manual with the manualfox search engine. Check results here:
http://manualfox.com/link/hinari.htm
Mar 03, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
54 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
ray gallant
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
