Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Hard to start. Been using starting fluid - Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
  • 186 Answers
Piston and or rings maybe worn perhaps.check sparkplug to see if you have spark first
Posted on Oct 14, 2010
2003 Volvo v70 shift hard in the first gear only when car in warm. It starts after the car has been on for 20 minutes or so?
start off by checking the transmission fluid when its hot and in park for the proper level,
check the color of the fluid compared to new fluid,
volvos probably use dealer specific transmission fluids and there is a possibility normal shelf trans fluid was used and that can cause all sorts of transmission problems.
hard shifts can also be related to transmission and or engine mounts. visually inspect those for wear and or breakage.
dark fluid or particles of metals on the dipstick can be a sign of major transmission problems
clean the dipstick off with a clean white rag to check that.
if its low make sure to use what the dealer recommends even if its high dollar, but if the fluid is already burnt smelling and or contains metal materials it getting time for a rebuild or replacement,
. at that price the previous owner might of known the transmission was going south.
good luck and hope you get more miles out of it.
May 16, 2017 | Volvo Cars & Trucks
Hard start wont keep running
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Use starting fluid to aid starting.
Jan 18, 2014 | 2000 Ford Excursion
Hard to start on short trips when cold
Jan 18, 2014 | 2007 Ford Focus (3 Door) Hatchback
My 2001 ford escape won't start . I checked all
Can\'t really help you with the no start problem without more information, but would advise you to stop using starting fluid right away. Starting fluid is hard on Diesel engines but they are made for much higher compression so will usually survive intermittent use of starting fluid. Gas engines just plain can\'t handle the much higher than normal compression that starting fluid produces which will destroy valves, piston rings, connecting rods, starters, ring gears on the transmission and head gaskets in short order. If you don\'t want to have to completely rebuild your gas engine don\'t use starting fluid on it ever!
May 12, 2013 | Cars & Trucks
My 2001 audi a4 V6 start but steering hard to turn. after i change the fluid.
Changed what fluid? If you changed the Power Steering fluid you must use Mineral type fluid. Pentosin CHF 11S is required I believe for that year. If you used regular fluid get it out quick. Why did you change it to start with? Normally never changed as a maintenance item.
Feb 05, 2010 | 2001 Audi A4
Very hard to start,used starter fluid and did starthad to kkeep pumpingh the acclerator,now turns over wont start
useing to much starting fluid will lock up your engine has the car been sitting for a long period if so u should check your fuel pump an for bad gas try this first before u spent alot of money
Dec 12, 2009 | 1995 Mazda 626
Starts hard when cold
Faulty idle control system/sensor, or intake gaskets leaking. If you've been using starting fluid on it, that would be why. Don't ever use starting fluid on a gas engine. If you're lucky enough to not blow your own head off, you aren't going to be lucky enough to cause extreme engine damage. ie: blown intake gaskets, bent valves etc.
Aug 09, 2009 | 1998 Chevrolet Blazer
Hard starting [cold] yank&yank&yank then i use starting fluid &
Starter fluid will help alot. just spray 2-3 bursts into the air intake and pull the cord. If if doesnt take off have a friend keep squirting as u hold on to it and the trigger.
Jul 27, 2009 | Garden
1981 Yamaha xj750rh that is hard to start
your idle/primary(pilot jet) circuit is blocked.Clean the carbs or have them professionally cleaned and put the starting fluid away.
Mar 22, 2009 | 1981 Yamaha XJ 650
Hard shifting starting in Drive Gear. Starting in
I agree with the suggestion to service the trans but no transX, just new fluid and a new fluid filter, if that doesn't help then you will need more seriou work.
Mar 15, 2009 | 1997 Mercedes-Benz E-Class
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
150 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
