Question about Vacuums
Ive got a miele revolution 5000 power plus and its just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=640910
Generic problem for all Vacuums
I’ve got a Miele revolution
Posted by rowler on Jun 02, 2008
I’ve got a Miele Revolution 5000 power plus and it’s just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not familiar with the light system on the Miele Revolution 5000 Power Plus
But it has something to do with the electronic hose assm or the circuitry in the vacuum itself. I have listed the factory phone # listed below for your further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/ Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Princeton, NJ 08540
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
How do I stop my miele revolution s758 from cutting out
If you pull on the cord's rewind and it cuts in and out, then the repair we do is to remove the rewind which is very simple, .....only one screw holds it in place!
Turn the rewind over so you can push the white take up wheel for the cord, and it will feel springy.
They are too springy some times when out of the factory and the 120V contacts will not connect to the line voltage.
Once you have pushed the white wheel in but not too much, drill a small hole in the brown shaft and slide a cotter pin through.
Remember not to push the white take up wheel in too hard while drilling because it will be too tight and the rewind will stick when you try and push the cords take up button!!!!!!
I hope this helps as it is the fix we use and have not had one come back for the same problem again!
William R!
Feb 12, 2015 | Miele Vacuums
How to replace cable cord
You will need to remove the screws where the cable enters the rear of the vacuum . You will notice the cable is retained with a small plastic clip , remove this clip, unscrew the cable cut out the damaged section and reconnect. Ensure retaining clip is replaced. Now put the screws back into the machine body,
Apr 26, 2014 | Miele S7210 Bagged Upright Vacuum
My cleaner keeps cutting out and now won't start
You can get a replacement hose from a vacuum store
Jan 04, 2014 | Miele Revolution 600 Bagged Canister...
My Miele Vacuum s5980 power cuts in and out?
Go to support on the Miele website. Enter your model number and search trouble shooting for your solution.
murf427
Aug 02, 2012 | Miele S 5980 + SEB 217 Bagged Canister...
Miele revolution 5000 no power light flashing
I would refer to your owner's manual. If the manual has no resolution, then I would contact the manufacturer directly.
May 08, 2012 | Miele Vacuums
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
This is a problem with the hose, and unfortunately it will require replacement of the entire assembly.
The SES-125 hoses produced in the general vicinity of late 2002 had a tendency to start building up static and kicking the motor off after a few years. The problem was rectified, and the more current hoses do not have this problem.
Head to your friendly neighborhood Miele dealer and get a new hose, and this problem will not occur again.
-R
Aug 27, 2008 | Miele Revolution 600 Bagged Canister...
Vacuums Logo
393 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
