Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Jenn air refrigerator temp gauge problem
Comment by eliramos, posted on Jun 02, 2008you guys keep saying turbo cool .. what is that and how does one activate it .. I turned off the refrigerator .. the temperature jumped to 71...plug it back in .. pushed the down arrow in the refrigerator to 33 (that's the lowest temp it allowed me to go) and went to bed at 9:30 PM .. at 4:30 am the temp read 59 and seems to be rising again (6:30 am) .. the freezer is still at 0 .. help
    Brigadier General:
  • 6,966 Answers
Hi again,
In your particular model I believe it is termed as "MaxCool". It is also possible that the sensor for the refrigerator is covered by a food item and therefore was getting erroneous readings hence cutting off early (making the temp go higher than normal). Based on this, you can try switching the food items around relocating them as to how they were placed inside. Incidentally, frequent opening and closing of the refrigerator of course would be exposing the inside to warmer air making the unit work harder.
The reset requires that the unit be unplug for an hour or more hence my suggestion during the Live Session to make use of a second refrigerator while checking out the Jenn Air.
Posted on Jun 02, 2008
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Seeking normal temperture range for 10 cubic foot refrigerator
Refrigerator temperatures should be between 34 to 38 for good cooling. Freezer temps should be from 0-15 to keep ice cream fairly hard
Mar 25, 2014 | Jenn-Air JCD2290HES Side by Side...
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
Hi, I have a jenn Air side by side fridge, and it keeps freezing everything. How can it be fixed?
your cooling temp is too low i take it you have decreased the thermis in this case the thermis is not working and will need replacing
best of luck
please remember to rank my reply
Dec 01, 2010 | Jenn-Air JCD2389G Side by Side...
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Same as below...
HELLO,
Is this fridge more than a year, if it is, then I would kindly suggest, :) to have a new coolant installed, and then run the fridge some time, it should kick back to normal...:)
Sep 09, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Water dispenser keeps flowing when water source is turned on
HI,
I have a little experience on your problem.S i suggest you to ask another experts advice.
Jun 13, 2008 | Refrigerators
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
397 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
