Question about Brother MFC 210C All-In-One InkJet Printer
I cannot get yellow & magenta to print. I cleaned the head numerous times but it does not help. i ended up placing the blue cart in the slot where the yellow & magenta was and did the test print and still only black and blue printed. What is the problem?
    President:
  • 261 Answers
Hi
if you didn't use printer for a long time your head need cleaning
Posted on Oct 14, 2010
  • arielali Oct 14, 2010
    I have actually been using the printer regularly. I
My printer prints in green not other colours
Most printers have 4 color inks: Black, magenta, cyan, yellow.
If your magenta ink isn't printing, then your prints will have a green cast.
If your printer has a "nozzle test", I suggest doing that. If it has a "head clean" function, that may help.
Replacing the magenta ink cart may be all that's needed.
Jun 20, 2015 | Office Equipment & Supplies
Yellow & Magenta not printing
Both print heads are clogged, try to clean it manually if not succeeded replace both of them.. U can find how to clean print heads in you tube..
https://www.youtube.com/watch?v=Ztl_SiUdPLw
Jul 29, 2013 | HEWLETT-PACKARD T790 InkJet Plotter...
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
Our epson t10 have this problem.. the yellow ink is not working. we try to print some graphics to test the inks. we're using the CIS cart. When we try to print, only the Magenta, blue and black is...
Hi Good day!! Try to try the head cleaning and alignment
1. Click "Start"
2. Click "setting"
3. Click "Printer and faxes"
4. right click your printer and then properties
5. go to printing preferences"
6. Click "Maintenance"
7. Choose Head cleaning.. after that you can align it.. by clicking "Align button. see if there is improvement in your printing.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 04, 2010 | Office Equipment & Supplies
Printer won't print yellow and blue.
Please Buy original hp printing catridge from an authirised dealer of hp.
Oct 26, 2009 | HP LaserJet 1200n Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
No black ink printing
Ah, solved already. Cleaning the black print head a few more times did it for me.
Mar 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have hp8250 photosmart printer it will not print magenta. all cartriges are genuine hp. I have cleaned printer heads numerous times. The problem is magenta only and no error codes show. when I print a...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Photosmart 8250 InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
760 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
