Question about Amana SXD524VW Side by Side Refrigerator
Amana SBS Water and Ice maker issues
About two weeks ago my ice maker started to make hollow ice cubes frozen on the outside and air on the inside. Since then I have noticed a delay in the water dispenser throught the door. I push the glass againts the leaver and there is a 2-3 second delay before the water dispenses. Now no water is going to the ice maker and it is therefore not producing any ice. The pressure from the water dispenser is the same as it has always been (good) but it now has the delay. Any thoughts? Thank you for your help
  • cuchuflo Jul 23, 2008
    I have a delay as well on the water dispenser of my Amana refrigerator. The delay in my case is something ridiculous like 30 to 40 seconds. The water pressure is still great but that delay is killing me.
    I have had some friends over to check it out and none of them have seen a problem like that before. They bwere looking for a filter but this refrigerator doesn't have any.
    Any ideas?
    Problem Solver:
  • 8 Answers
The water solenoid on the back of the refrigerator at the bottom is becoming clogged. There is only a very small hole in the diaphram of the valve. I suspect you have very hard water, or at least a fair amount of sediment in the water.
This valve will most likely need to be replaced by a qualified technician.
They sometimes can be cleaned, but it doesn't always work.
Posted on Jun 10, 2008
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Water and Ice maker problems
sounds like you water lines may be kinked or clogged.
follow you water lines and see if there is a kink in the line that would be the easiest thing to check first.
Jun 02, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana bb120 bottomfrezer ice makerwon't work
HOLLOW ICE IS ALWAY A SIGN OF A WATER INLET VAVLE FAILING
May 31, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
309 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
