Question about Plantronics Explorer 340 Wireless Headset
Hi, . I'm trying to Pair my bluetooth to my phone once device is found its asking me for a pin. I don't have one can you please help me. Thank You
  • 638 Answers
Usually the PIN is 0000. Try it and let us know if this fixed your problem.
Posted on Oct 14, 2010
How do I pair my Samsung Galaxy J3 with my bt 02A2 Bluetooth speaker
Hi Sandra,
Press and hold the power button on the speaker. The lights on the speaker will start flash red and blue. Now open up the bluetooth menu in your phone and search for new bluetooth devices. Once you see the device, select it. If it asks for a pin, try 0000.
Mar 13, 2017 | Samsung Cell Phones
Trying to pair the Sylvania Sp260 bluetooth with my phone and it keeps asking for the pin where do I find this?
Hello there, welcome to FixYa.
To solve your problem: all Bluetooth devices use a default code/pin which is: 0000 (4 x zero). I hope this helps!
Please rate this solution.
Kind regards
Dec 25, 2012 | Sylvania SIP286 iPhone Speaker with...
Whatis the bluetooth pin for samsung c6112
check the bluetooth in settings go into bluetooth .. turn on bluetooth and phone will scan for devices to pair with. The other device will show if it has bluetooth on and set to discoverable.
Under available devices on your mobile touch with finger it will try to pair and say boothtooth pairing request. Confirm passkey is {whatever number it generates} to pair with {whatever device it is pairing with } note what the number is and press ok. At the top of the screen is a note says visable to all nearby bluetooth devices . the box needs to be ticked and other device should have same pass code when it tries to pair. It will ask you to confirm code.
Jan 12, 2018 | Cell Phones
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
Need to reset plantronics voyager pro heatset it pair with wrong phone and i cannot reset it or know how
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Mar 22, 2011 | Plantronics Discovery 925 Bluetooth...
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
How to pair with samsung tocca?
On your Tocca
Press menu
Bluetooth
Press the phone in the centre of the screen and it will search for other bluetooth devices
The other devices will appear when they are found
When your Parrot appears touch it and drag it into the centre
It will then connect and ask for pin
Enter the same pin on both devices and then your ready
If this doesnt help let please let me know and i will try to help you further
JonnieC
Dec 16, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Connecting phone to bluetooth
had the same problem but this site reminded me to hold the phone button down 7-8 seconds. I was simply not waiting long enough - took more like 12 seconds.
Apr 05, 2007 | Jabra BT250 Consumer Headset
Plantronics Explorer 340 Wireless Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
