Question about Canon NP 6551 Black and White Copier
Error code e002
What doews this code mean
  • 31 Answers
Refers to a problem in the fuser assy. Could be a blown thermistor or lamp. Remove fuser assy & check continuity on thermistor & lamps. Lamps must be disconnected to test. Error will have to be reset in service mode after replacing bad component.
Posted on Jun 02, 2008
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
I have an error code E000 on my canon copier what could be the problem
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 20, 2011 | Office Equipment & Supplies
Error E000
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon ImageClass D880 Copier
Canon Imageclass D860 - I have a System Error E000 code on the LDC display. No paper jam or other problems evident. Disconnected power for 10 minutes and that didn't help. For this error code I am to...
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon Office Equipment & Supplies
Falla cannon
Hope that helps...
Lbcoaster
Jul 11, 2008 | Canon ImageClass D880 Copier
System Error E000
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
Jun 05, 2008 | Office Equipment & Supplies
Error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Canon PC-850 E002 Error Code
After some searching, it appears that this error is common on all Canon Copiers. It means that "Fusing unit not heating up" This is most likely due to a bad fusing unit, or a component the fusing unit. Recommend replacing Fusing Unit.
Mar 19, 2008 | Office Equipment & Supplies
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
Canon NP 6551 Black and White Copier Logo
old marine
old marine
