No sound from monitor or external speakers - Computers & Internet
    President:
  • 261 Answers
Hi
check in device manager is your sound card driver installed properly
there shouldn't be this (!) symbol
2 check the volume icon in task bar (mute or in lowest rate)
Posted on Oct 14, 2010
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
Have the gateway fpd2275w monitor -it has external speakers added to it.I want to get rid of them.How do I go back to original sound ?
Hello Alex,
The Gateway FPD2275w does not have built in speakers so the external ones are needed if you want to have sound. You can either have the external speakers or you can use a set of headphones.
Oct 31, 2012 | Gateway Computers & Internet
The speakers on my monitor dont work but if i plug headphones in th back of my computer i have sound.had sound in the eveningbut in the morning had nothing is my moniter dead??
First try wiggling and twisting the the mini jack in the socket, that feeds the monitor speakers signal.
Both ends.. at the PC and at the monitor. Hopefully it's that simple.
The other thing to check is - Do you have a seperate power supply for the speakers? Ck it's still plugged in, to the power, and to the speaker feed.
Test the output with a meter to see if it failed. This can be replaced. (Would be cheaper to buy new speakers)
IF no joy at this point, it possible the speaker circuit in the monitor has failed, or the internal power feed to the speakers (if no external one)
Replacement external speakers are not at all expensive, unless you really need Hi Fidelity. That seems unlikely, as you are using monitor speakers which are as poor fidelity as most come.
I'll bet a $25 set of external speakers will sound 10 time better than the monitor ones.
Feb 10, 2011 | Computers & Internet
No sound, other monitors have a input jack for sound but not this one.
Some monitors have built-in speakers and others do not have them.
In this case you need to purchase separate external speakers to connect into your computer. If your computer has audio output for surround sound, then you can buy 5.1 surround sound speakers. These will have 2 front speakers, 2 back speakers, a center speaker and a sub-woofer speaker..
Jun 04, 2010 | LG Flatron L2320A 23" LCD Monitor
Just hooked up computer and monitor and cant get any sound to play through moniter. do we need external speakers?
The Samsung SyncMaster 2233BW does not have built-in speakers, so yes, you need external speakers separately for sound.
Feb 06, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
No sound
no if external speakers work that means that the sound card is absolutely fine>
now let me tell u the computer itself doesnt have any in built speakers>
either u connect external speakers or the monitor that u use should have speakers built with it> then u connect the monitor to the computer then also use a thin sound cable from the monitor to the back of the computer on the green port
Oct 07, 2009 | HP Computers & Internet
Cant get speakers on my monitor to work after I unhooked external
IF you have xp go to control panel/sound,speech and audio. You will see a drop down choice that says change speaker settings. Click on this. Then under the tab that says speaker settings hit advanced. Then select the sound scheme that says monitor with stereo speakers and apply this. Assuming you still have a functioning sound driver this should return it to the monitor speakers. Hope this helps.
Mar 29, 2009 | HP (400745-001) Sound Card
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to...
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Dec 12, 2008 | Acer V223WBD Monitor
No sound from monitor speakers
The monitor must plug into the PC as the external speakers did.
Apr 16, 2008 | Westinghouse L1928NV Monitor
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
