Question about Kenmore 92812 / 92814 Electric Kitchen Range
Kenmore Model 911.92812301. Everything works, but broiler gets too hot (the top of the stove) and we get a strong electrical smell. Afraid to use it. Has been that way since day one, but we didn't get it fixed under warranty.
  • Kenmore Master
  • 3,051 Answers
Hello there:
This has been a problem that these ovens have had The problem that the oven electronic temperature sensor is getting either a bad reading from the controle board or the sensor itself is faulty
When this happens the oven will continue to heat up till it reaches a runaway temperature generally 550 degrees
So what you will want to do is remove the temperature sensor and have it tested it should read at least 1000 ohms if not it needs to be replaced
Posted on Oct 14, 2010
  • sdsherer Oct 14, 2010
    I'm not sure how to ask a follow-up question, but this comment box seems to be the only way...
    Is this temperature sensor the same one that the oven uses? Because the oven itself seems to be fine; it's just the broiler that is messed up.
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Kenmore elite stove model #7909912949B. Can get anything to work on oven. Light comes one. Nothing else in the enter panel. Top burners work.
Can you enter the oven temp and press start on the control panel? Do you hear it click on, but it just does not get hot? Try turning on the broiler and see if the broiler gets hot.
Feb 01, 2015 | Kenmore Kitchen Ranges
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
Why won't the broiler flame on my kenmore gas stove adjust?
you may have to replace the orifice with a smaller one. Follow the gas tube from the broiler to see if it runs thru the same regulator. Some units use a pressure regulated gas valve.
Aug 22, 2014 | Kitchen Ranges
Kemore gas range model #790: oven does not get hot, but stove top and broiler both work
Hello- Sounds like lower burner ignitor is bad. Resistance should be more than 4ohms. across ignitor. Parts available locally at app. parts store for 50-75$. Fairly easy to install. - Hope this helps. Thanks- ED
Feb 27, 2010 | Kenmore Kitchen Ranges
Preheated stove put in cake a few minutes later smelled burning and cake was burnt on top.. Broiler was on and running hot as heck. tried turning off stove but would not shut off.. Unplugged. Let satand to...
Probably the control relay has shorted. But first check the voltages at your receptacle to insure that a neutral is not floating. You should fine 120 from each hot to the neutral.
Jan 09, 2010 | Kenmore Kitchen Ranges
Top broiler igniter lights, but no gas is coming
The ignitor should glow almost white hot. If it is just red hot it may not be drawing enough amps for the valve to read and not allowing it to open and releasing the gas. It should pull 2.5 - 3 amps for the valve to open.
Aug 04, 2009 | Kitchen Ranges
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 92812 / 92814 Electric Kitchen Range Logo
210 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
