Question about HP Photosmart C4180 All-In-One InkJet Printer
My printer says it has a paper jam however there is nothing in it. How to fix?
    President:
  • 261 Answers
Hi
its may be a piece of paper still on sensor that check paper
Posted on Oct 14, 2010
  • 121 Answers
SOURCE: Brother HL-2040 printer
if someone directed you to take the printer apart, there's probably a panel or door that isn't closed or in place all the way.  Take it all apart again and start over.
Posted on Oct 27, 2007
SOURCE: carriage jam
i have the same problem i have a carriage jam problem please tell me how to fix it i have a mesage clear carriage jam and then press ok.
Posted on Jan 21, 2008
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
SOURCE: Paper jam
I had this exact problem, but pressing the tray down did not help... But i was on to something. There must be a sensor there, so i tried to blow some air down under the plastic, if some dust should have entered. And then it went like a charm. Kristian
Posted on Oct 12, 2008
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
Why my canon printer is saying paper jam?
here is nothing wrong in saying, "paper jam issue in canon printer " one of the most irritating issue.
especially when you are going to print any import document and it got stuck in the middle of printing.
when we face paper jam issue with our printer. we always try to contact to a technical expert for fixing such kind issue. while most of us don't know, you can fix paper jam issue in canon printer by yourself without inviting any technical person at your home.
For More details check this
how to fix paper jam issue in canon printer by myself Fixotip
Jan 02, 2018 | Canon Office Equipment & Supplies
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
My hp deskjet f2430 is showing that there is a paper jam. I have put paper in the printer and it still shows that there is a jam. How can i fix this?
A paper jam usually means that there is paper stuck inside the printer, I would start by taking a flashlight and looking inside the printer were you put the paper in and make sure there is nothing in the way there. You can also try to open up the printer, most have a few places that you can take apart easily and look inside to make sure there is nothing jammed. If you cannot get into the printer then the next best thing would be to take the printer down to a local computer shop and see if they can tell if there is anything in there really quick. Most decent shops will not pay to look into the printer really quick.
Apr 05, 2011 | Office Equipment & Supplies
Canon MP470 printer jam error
hi...open the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Kodak 5300 AiO Printer will not work due to paper jam
Looks like the sensor for paper jam is causing you problems.
Worst thing is that Kodak discontinued the whole 5xxx series because of all the problems those printers had.
I don't know if you will be able to fix the problem through Kodak support, I guess you will have to give them a call.
Good luck,
Milan
May 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Imaginary paper jam
theres a paper jam back door in the back of the printer open that up see if theres papers there or something like hair or bug
May 30, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Paper Jam
i did exactly as iamzwalrus said and it fixed.go with that if nothing eles works.
Apr 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
124 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
