Question about Charanga GuitarCoach Full Version for PC
Purchased electric guitar coach deluxe on 13.10.10. 6cd-roms. on instalation found that there is no disc5 but 2 disc6 . I am unable to instal any way I can get disc5
I have an american delux telecaster with noisless pickups and it started to produce and annoying buzz sound and i am getting electricuted everytime I play and touch the mic and i have a strong feeling its...
You are looking at the WRONG end of the guitar cable. You have a VERY unsafe guitar amplifier OR the mixer that is connected to that mic has an UNSAFE grounding condition.
If your guitar amp is an old one that has a two wire cord and a switch you change to reduce hum, take it in to have a three wire power cord installed IMMEDIATELY. Only plug into grounded receptacles. This is needed to reduce electrical noise and hum but MORE importantly is personel safety.
If the problem is with the mixer and the electrical service to the mixer, better get a professional in to analyze the problem before somebody is injured.
AS A START do this: VERIFY that ALL interconnected equipment INCLUDING your guitar amp iis powered from the same source or receptacle. This includes the venue power amps, mixer, any CD players, etc. Professionals run power back from the stage source to the mixer alongside their snake to avoid just the problem you are seeing. When they need more power at a venue, a power distribution box is used that conditions the building power and insures grounding.
Mar 25, 2011 | Fender American Deluxe Telecaster
I have Charanga Guitar coach ver 2001. It used to
This is because of software compatiblity of the old version Charanga Guitar coach v 2001. with your Vista OS. Try to install the program as "Administrator" and run the program in the "compatiblity mode". If you can't install the program you have to get a newer version which is ciompatible to Vista.
Read this link @ http://www.etcetera.co.uk/products/CHA002.shtml
Jun 30, 2010 | Charanga GuitarCoach Full Version for PC
Unable to install card studio 2009 has dvd-rom instead of cd-rom
Well, you have a couple of choices:
1) You can have a DVD installed in your computer. Usually around $50.
2) You can purchase a flash drive (thumb drive) of at least 4GB. Depending on the size of the files, you may need an 8GB. You can have a friend copy the entire DVD onto the flash drive. Then you can take the flash drive and copy the entire DVD from the flash drive to your computer and install the program or install directly from the flash drive. (It may auto start when you insert it into a USB port.)
If you install it from the flash drive you will probably have to insert it every time you run the program. If you copy the DVD to your hard drive you will not have to and it will run faster.
Thanks for using Fixya.
Nov 10, 2009 | Hallmark Card Studio 2009 Deluxe Full...
I'm unable to install 3D home designer deluxe edition
Under Organization, did you leave this blank? Sometimes you have to even tyoe "None" if this is for personal use. Please also check your number and make sure your "-" are in the correct spot. If this all fails? Return this product for an exchange for the exact item from where you purchased it.
Hope This Helps
Oct 06, 2009 | Computers & Internet
Schecter Hellraiser C-1 question
Yes, you can install a Floyd Rose later, but it will cost you more to buy one later and install than if you were to purchase the Schecter with it already installed. A Floyd Rose bridge with trem can cost between $40.00 for a used one, to $80.00, or even higher, depending on the features you want. If you need it installed for you, you are looking at another $50.00 to $100.00 potentially.
If you are unable to purchase the one without the Floyd Rose bridge because the cost is a bit out of your reach, don't worry. Schecter C-1 guitars are well made and sound very nice, and you would still have a really nice guitar. I have owned two Schecters , and still kick myself for having sold them to "upgrade" to a Gibson Les Paul Standard. Just because it reads Gibson on the headstock, doesn't necessarily mean it's a better guitar. To prove that, check out reviews on Harmony Central sometime (www.harmony-central.com) and see how many people are displeased with their Gibsons, and how many are pleased with their Schecters.
But you don't have to worry about installation of a FL bridge later, as they fit exactly where the standard bridge and stop tailpiece are fitted.
I hope this helps.
Jul 16, 2009 | Schecter C 1 Hellraiser Electric Guitar
MCI Error from SHOWMCIWND The Device Driver is not Ready
Mark
I also had same problem.
Go to
http://www.musiccoach.com/technical_support/errpages/mciset.htm
and install
http://www.musiccoach.com/technical_support/downloads/indeo32fix.zip
open, unzip, install "setup"
After this you can see all video.
Don't forget to set properties of file "charang guitar coach" : open with right click of mouse, open the tab "compatinbility" and set "compatibility mode to windows 98/ME or windows 95
Good playing guitar
Fausto Viegas
Jun 28, 2009 | Charanga GuitarCoach Full Version for PC
I found a cd-rom for Dinosaur Hunter, but when I try to install it for my son, it doesn't install the sound portion, and when I try to run it, it says that the sound wasn't installed properly and that I...
Try running the install in compatibility mode for windows xp. Do this by exploring the cd rom, right clicking the setup file, and select compatibility, run this program in compatibility mode for win XP sp2.
Nov 29, 2008 | Dk Multimedia Dinosaur Hunter Deluxe...
Charanga GuitarCoach Full Version for PC Logo
57 people viewed this question
Top Charanga Computers & Internet Experts
David Payne
David Payne
Are you a Charanga Computer and Internet Expert? Answer questions, earn points and help others
