Question about Garden
I have a Tecumseh LH318SA engine spec # 156561H on my Arians Sno thro machine. A rock got sucked up and caught between the flywheel and pick up coil and ripped the coil and coil posts that are part of the engine off, I'm need a new engine but am told the engine is no longer available, what is the shaft size or if any key knows of a direct replacement
SOURCE: carbourater for a tecumseh engine
start by closing jets (clockwise). Then turn jets 1 full turn counterclockwise. this should get engine started. Then adjust jets left or right to fine tune,until engine starts running smoothly.
Posted on Aug 10, 2008
  • 195 Answers
SOURCE: Ariens SnoThro w/5hp Tecumseh has no fire
Check the fuel. Pour some fuel into a clear jar and let it set. See if it seperates due to water in the fuel. Very common problem.
Rich
Posted on Jan 15, 2009
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
lemmingleejn
  • 173 Answers
SOURCE: need to know the size to use to gap the coil and
The gap will vary, depending on engine wear.
If you have a ' feeler gauge', it won't take you long before it runs beautifully.
That's it,
oh and, don't forget to rate:)
Posted on Jul 28, 2009
  • 7 Answers
SOURCE: Tecumseh LV195EA Starts then dies.
If the engine is running at all then your sensors should be ok. It sounds to me like its starving for fuel? Once the engine runs out of prime then it starves. Does the fuel system have a shut off valve? How about an inline fuel filter? Either could be plugged. I think what you will need to do is remove the carb from the engine and check to see if its clean and if fuel from the tank is flowing easily to it. Once you have the carb off the engine, remove the bowl from the carb by removing the bottom bowl nut. Use a small can or an ash tray to hold the small pieces. Shake the float back and forth to see if there is anything in it. Some floats are plastic and some are tin. If there is any liquid inside the float there is your problem. Otherwise continue on with your diagnosis by using a bread bag wire, minus the outer covering, and a little jet spray to probe and clean the internal jets. Pay particular attention to the center main jet which will have a small perpendicular air bleed hole near the bottom and to the air vent hole that is on the face of the carb where the air cleaner mounts. Any tiny piece of chaff will cause these to plug. For reassembly, the inlet needle slides into the float, and they are held to the casting by a pin. You can push the pin out with a small screwdriver and then grab it with a pair of needle nose pliers to get access to the float. Finally, check the O ring for cracks that goes between the bowl and the casting. This is an easy job, just take your time. Lawnboys are one of the better machines.
Posted on Aug 31, 2009
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
No spark on my murry riding lawn mower it has a tecumseh ohv135 replaced the spark plug
clean the flywheel, and the contact area on the coil. if this doesn't fix it then you need a new coil.
Nov 03, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I'm looking for a free repair manual for a Tecumseh snow blowere engine, model #LH318SA
you can go to there main web site and print it out on your printer.
Feb 05, 2011 | Computers & Internet
No spark on tecumseh 4 hp lawnmower engine
There is a shutdown wire, this wire is grounded somewhere along the route. Look at the coil for this wire; it shorts the coil to ground so no spark can get out to the plug.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
May 28, 2010 | Sport & Outdoor - Others
Bolens garden tractor will not start
At this age, the engine will have points under the flywheel. If the coil is OUTSIDE the flywheel, forget fixing it and just replace the coil with a later solid state unit, then cut the points wire.
If the coil is UNDER the flywheel with the points, you'll have to stick with them, but replace them AND the condenser. These parts (and replacement coils) are still available, but decide quickly - Tecumseh have gone, and when all these old parts are used up, that's it.
May 08, 2010 | Garden
Magnet location on flywheel of a tecumseh 4 hp on a Ariens snow b
what is going on with the magnets on flywheel or are you talking about the magneto ( coil)
Jan 13, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Rich
Jan 15, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Rope snapped in my recoil starter..
take off the and and turn the coiler on the inside a few turns and when it starts to get tight put a screwdrive through it so it wont spin, put the rope in the hole and bring it out and tie a knot. the turn it gently to release the screwdriver and let it coil the rope back in
Jan 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
