Question about Coleman Powermate Powermate 5000W Generator
My coleman powermate 5000W generator is very hard to start. When I squirt gas in the carburator chamber it will start for a about a minute and then it dies. It acts like it is not getting any gas. I removed the carburator and cleaned as best I could and is still doing the same. Is there any adjusment that need to be reset. Thanks Carlos
  • 68 Answers
The carb. has a nut holding the bowl on.Remove this nut and you'll notice a hole in in it that goes from side to side.You'll also notice one through the center that connects to the other.Make sure these holes are clean.Use a small pin..etc.Chances are it will stay running when you assemble the carb again.
Posted on Oct 21, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Gas flows from cutoff valve to carburator hose connection but does not flow into carburator. What is blocking the flow?
On the top of the carburator there is a needle valve, closed by the float lever.
If the carburator chamber is full with gas, the valve is closed and no more gas can enter the chamber.
If the chamber is empty and no gas flows inside, the valve may be stuck in closed position. Cleaning or some sharp (but not very hard) knoks on chamber cover may help.
Some times the float gets broken and falls down. This is a bigger damage, because it may lead to carburator overflow.
Jul 19, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 6250 generator - shut off generator at 11pm after v4 hours normal use. At 5am, wouldn't start, pull rope wouldn't move to start. A few hours later while draining oil found mostly gas...
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak.
if all else fails always turn off the fuel supply to the generator whilst not in use
Oct 21, 2009 | Coleman Powermate Powermate 5000W...
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
Won't start
low oil switch stuck. most new small engine have a low oil swich in the oil pan. this can be by passed or replaced.
Dec 21, 2008 | Coleman Powermate Subaru 5000W Portable...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
306 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
