Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Steps needed to change transaxle belt - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • 110 Answers
Lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Posted on Oct 25, 2010
2006 Troy Bilt Super Bronco riding mower. How can I grease the rear end?
Hi, Your Troy-Bilt has a sealed for life transaxle and requires no service. However, there have been some issues with the CVT clutch assembly bushings. Since there are no lubrication points, if the unit will not reach top speed or changes speeds abruptly, the first thing to inspect is the drive belt wear and tensioners. If the belt is in good condition then the bushings, and/or the clutch assembly will need to be replaced. I hope this helps and feel free to reply back if you need further assistance. Here is a link to the transaxle and clutch assembly;
Troy Bilt 13AX60TG766 Troy Bilt Super Bronco Lawn Tractor 2006 Drive...
Mar 14, 2016 | Troy Garden
Drive belt diagram model 917-276051
the closest thing to a "drive" belt diagram would be in the owners manual http://www.manualslib.com/manual/487688/Craftsman-917-276051.html?page=38#manual
the horizontal (front) end would be to the pulley at the engine that the deck belt(s) are not attached to. There is a set of mid pulleys where the direction is changed from horizontal to vertical for attachment to the transaxle.
Jul 01, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need head bolt torque specs for a 2000 cadillac deville dts..
DeVille, Eldorado, Seville 1999-2005
Cylinder Head
Print
Removal & Installation
Left Side
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Properly relieve the fuel system pressure.
  4. Remove or disconnect the following:
    Negative battery cable Exhaust manifold Alternator Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Power steering return hose retaining bolt from the cylinder head 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket.
  5. Clean the head mating surfaces.
To install:
Fig. Left cylinder head bolt torque sequence-4.6L engine
  1. Install the cylinder head with a new gasket. Lubricate the bolts with engine oil prior to installation.
  2. Torque the M11 bolts in sequence as follows:
    1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees
    2. Step 2: Turn an additional 60 degrees
    3. Step 3: Turn an additional 60 degrees (total 190 degrees)
  3. Torque the M6 bolts to 106 inch lbs. (12 Nm)
  4. Install or connect the following:
    Power steering return hose retaining bolt to the cylinder head and tighten to 37 ft. lbs. (50 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
  5. Change the oil and filter.
  6. Fill the cooling system.
Right Side
    Negative battery cable Exhaust manifold Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Electrical connector from the Engine Coolant Temperature (ECT) sensor Nut attaching the coil cassette ground wire to the cylinder head Bolt attaching the exhaust crossover pipe to the cylinder head Bolt attaching the right transaxle mount bracket to the cylinder head Bolt attaching the rear transaxle brace to the transaxle Nuts attaching the rear transaxle brace to the cylinder head Rear transaxle brace 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket
To install:
Fig. Right cylinder head bolt torque sequence- 4.6L engine
    1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees.
    2. Step 2: Turn an additional 60 degrees.
    3. Step 3: Turn an additional 60 degrees (total 190 degrees).
  3. Torque the M6 bolts to 106 inch lbs. (12 Nm).
    Rear transaxle brace over the studs located at the rear of the right cylinder head Nuts attaching the rear transaxle brace to the cylinder head, loosely Bolts attaching the rear transaxle braces to the transaxle and tighten to 37 ft. lbs. (50 Nm) Nuts attaching the rear transaxle brace to the cylinder head and tighten 37 ft. lbs. (50 Nm) Electrical connector to the ECT sensor Bolt attaching the exhaust crossover pipe to the cylinder head and tighten to 18 ft. lbs. (25 Nm) Nut attaching the coil cassette ground wire to the cylinder head and tighten to 13 ft. lbs. (17 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
Apr 16, 2013 | 2000 Cadillac DeVille DTS
Mitsubishi mirage 1995 50,000maitenance requirements
MAINTENANCE INTERVALS FOR 52500 MILES IS ENGINE OIL AND FILTER CHANGE.TIMING BELT CHANGE IS 60000 MILES INTERVAL. MOST OF ENGINE TUNE UP IS DUE AT 60000 MILES INTERVAL.YOU NEED TO REPLACE TIMING BELT, REPLACE ENGINE COOLANT, REPLACE SPARK PLUGS,REPLACE IGNITION CABLES. REPLACE ENGINE OIL AND FILTER. YOU NEED TO SERVICE AND INSPECT ALL THESE ITEMS, AUTOMATIC TRANSMISSION FLUID AND FILTER,BRAKE HOSES, BRAKE PADS,DRIVE SHAFT BOOTS,VALVE CLEARANCE,BALL JOINTS AND STEERING LINKAGE SEALS,DRIVE BELTS,EXHAUST SYSTEM,FUEL HOSES,MANUAL TRANSAXLE OIL,REAR DRUM BRAKE LININGS AND REAR WHEEL CYLINDERS.
May 21, 2011 | 1995 Mitsubishi Mirage
My mower keeps throwing the drive belt. I have changed belts and the same thing happens. It is a Simplicity riding mower.
I would be taking a very close look at the drive belt pulleys and their bearings. If that is all good then replace the springs which maintain the tension. There is some extra slop in there somewhere allowing the belt to run out of the groove.
Aug 12, 2010 | Garden
93 plymoth grand voy SE transaxel problems
Try trans x to try and clean the filter in the transmission,you can purchase it at an auto parts store,if the filter is stopped up,it will clean it ,and you will be on your way.Also,a product only available at N A P A auto parts call Lube Guard.I hope this will help you thank you.
Oct 30, 2009 | 1993 Plymouth Grand Voyager
Need to change cv outer boot on mazda ba 94 model.
it just pulls out. it hasa circlip that holds it in on driver side. which side?
here's an escort, should be similar. note step 17
Removal
  1. Raise and support the vehicle.
  1. Remove the lug nuts (1012) and the front wheel and tire assembly.
  1. Remove the front fender splash shield bolts and the front fender splash shields (16103) .
  1. Use a small cape chisel to carefully raise the staked portion of the front axle wheel hub retainer (3B477).
  1. Remove the front axle wheel hub retainer and discard it.
  1. Remove the cotter pin and the tie rod end nut from the tie rod end (3A130). Discard the cotter pin.
  1. Use an appropriate tie rod end remover to separate the tie rod end from the front wheel knuckle (3K186).
  1. Remove the ball joint bolt and the ball joint bolt nut.
  1. Carefully pry down on the front suspension lower arm (3078) to separate the front suspension lower arm ball joint (3050) from the front wheel knuckle.
  1. Pull outward on the front wheel knuckle (3K185). Carefully pull the front wheel driveshaft and joint from the front wheel knuckle and position it aside.
  1. NOTE: Removal of the LH front wheel driveshaft and joint (3B437) requires removal of the transmission support crossmember (6A023) to allow access with a pry bar. If the LH front wheel driveshaft and joint is being removed, continue with step 11. If the RH front wheel driveshaft and joint is being removed, continue with step 15.
    Support the transaxle with a transaxle jack or equivalent.
  1. Remove the four transaxle mount-to-rear engine support nuts.
  1. Remove the two rear engine support nuts at the rear of the transmission support crossmember.
  1. While supporting the rear of the transmission support crossmember remove the two rear engine support bolts. Remove the transmission support crossmember.
  1. Position a drain pan under the transaxle.
  1. Insert a pry bar between the front wheel driveshaft and joint and the transaxle case.
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Extreme care must be taken to ensure that the pry bar does not damage the transaxle case, the transaxle oil seal, the front wheel driveshaft and joint, or the front wheel driveshaft joint boot (3A331).
    Gently pry outward to release the front wheel driveshaft and joint from the differential side gears (4236).
  1. Remove the front wheel driveshaft and joint.
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: When the LH and RH front wheel driveshaft and joint assemblies are removed, Transaxle Plugs T88C-7025-AH must be inserted to prevent the differential side gears from becoming mispositioned. If the gears become misaligned, the differential will have to be removed from the transaxle to align the gears.
    If both front wheel driveshaft and joints were removed, install Transaxle Plugs T88C-7025-AH in the differential side gears.
  1. Remove and discard the driveshaft bearing retainer circlip (3Z498).
Oct 03, 2009 | 1994 Mazda 323
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
1991 Chevy Cavalier Transaxle removal
you need to support engine.you need haynes repair manual. you have 58 steps to remove transmission.it would be easier to have repair manual.
Apr 13, 2009 | 1991 Chevrolet Cavalier
Ride-on Lawnmower wont switch gears smoothly
Hi..my name is Keith..and yes..there is a disc brake..that is your brake/clutch.. and it stops the transaxle..its usually located on the transaxle ..on the right side..i hope this has helped..if now please write back
Mar 31, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
307 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
