Question about ViewSonic VX1932WM LCD Monitor
Power light flashes on start up, screen doesn't light up
  • 11,361 Answers
Try it other PC first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 14, 2010
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
DSI XL won't power on, but orange charge light is solid (doesn't blink) when charging.
dsi xl getting wrong voltage at plug that goes to the battery. I have 5.78 from charger at battery connections I have 5.78,3.87,0.45,1.98 it bounces all over any ideas?
Jan 25, 2013 | Nintendo DSi XL Console
My remote doesn't work
Do you have any flashing indicator lights on the remote? If you don't you can verify your remote is sending IR signals by pointing a cell phone camera at the front of the remote and viewing through your cell phone screen while holding down a button on the remote. You should see the flashing IR light on your cell phone screen. If you do not see the flashing light either the batteries are no good, or the remote is not getting power due to a problem with the circuit board.
Nov 23, 2012 | Apex Digital Apex 40" Class 1080p 60Hz LCD...
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My net acer zg5 AOA150 doesn.t go. He start only the light "on" but it doesn't go
you need a flash drive fat32 formatted,download the bios update from acer website.copy the flashit.exe & 3114.fd to flash driverename 3114fd to ZG5IA32.FD.insert ur flash drive to the right side usb port. turn on power while holding Fn and Esc key don not release the combination key until u count of 7 sec, when light is on push again the power button then release.it will blink in a minute and the light turn off, don't do anything until it restart. just relax it takes a minute.if you can't download the file e-mail me @ fccaole@yahoo.comgood luck guys! wait for 7 second to release
Jul 30, 2011 | Acer Aspire One AOA150-1784 Netbook
Hello. We were hoping that you can help. We have a Toshiba LCD, 40G300U3. When we turn the power on, the green power light turns on and we can hear sound coming from the speakers ... however the screen...
Take a flash light into a dark room with your laptop, and shine it into the screen when it is on. If you can see the screen then more than likely your back light is out.
If you do not see an image with the flash light, then more than likely your motherboard or LCD is going bad, this needs to be tested by a computer profession to see which is going bad.
Jul 17, 2011 | Toshiba Televison & Video
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
ViewSonic VX1932WM LCD Monitor Logo
114 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
