Keeprite Furnace HGD-60 Manual - Heating & Cooling
2 Suggested Answers
pedwysocki20
SOURCE: keeprite furnace manual
for a few days now my furnace "when it starts theirs a loud whining noise , i did check the noise is coming where the motor area is.. its stops when the blower comes on....but it getting louder! so is it one of the fans??
Posted on Nov 09, 2012
Keeprite Mid Efficiency furnace. Why won't blower shut off?
The thermostat may be set for continuous blower operation.
Dec 17, 2015 | Heating & Cooling
My keeprite furnace not working getting 3 green flashes
Pressure switch open, when it should be closed.
Oct 24, 2015 | Heating & Cooling
How do I change the furnace filter in a Keeprite CC18?
there should be an access where the cold air return goes into furnace.
just slide filter out
Feb 11, 2015 | Filter Heating & Cooling
Keeprite fornace is giving ten flashes .what is the problem
Short cycling is very comon when you have a dirty filter.
May 18, 2014 | Tools & Hardware - Others
I have a keeprite furnace that is acting up the furnace starts up and runs some times for minutes and sometimes seconds the pressure switch is cutting in and out but it doesn't seem to have a steady flow...
TEMPORARILY disconnect exhaust vent and see if it still does it. If it runs for a few minutes like that, normally your problem is something in your vent pipe. If plastic vent pipe, even a puddle of water, if the pipe is not sloped correctly. Water in the vent pipe has to run downhill all the way to the furnace. If metal vent, probably a clog somewhere.
Nov 07, 2013 | Heating & Cooling
Keeprite furnace
Is the furnace sitting directly on a concrete floor? If it is, it is taking up moisture from the floor. You need to get it up on blocks or some very solid base.
Oct 26, 2013 | Tools & Hardware - Others
How do I get the impeller off the motor shaft for the blower on my keep right furnas
You don`t. I know it is crazy when the motor is cheap but that is the way they designed it. The inpeller will break before it comes off and if it don`t there`s no way to keep it on the new motor. Sorry. I`ve tried it.
Feb 04, 2011 | Omega Keeprite Furnace Flue Exhaust Venter...
Keeprite furnace manual
Oct 03, 2010 | Heating & Cooling
Keeprite furnace will come on heat up but the fan or blower doesn't blow but creat noise. please tell me how can I fix it. Regards Andre
Blower motor is either burnt or Ihave also seen the fan relay on the board burnt..test for 120v power out of the board at the blower leads if so replace motor, of no replace board
Feb 06, 2010 | Omega Keeprite Furnace Flue Exhaust Venter...
Furnace not blowing air
this may sound not useful but the first thing to try is turn off the breaker or fuse to the feed for the furnace for 1 minute and turn back on and listen and note exactly what it does from there and will have better idea how to help and this might fix the problem try and let me know th results
Dec 31, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
247 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
