Question about Sony XPLOD CDX-GT200 CD Player
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
    Problem Solver:
  • 9 Answers
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Posted on Dec 25, 2010
Got a 1991 honda civic hatchback dx for a starter car and its automatic, when it wants not all the time,so im driving 30mph and for some reason it like slips than catchs back on gear any ideas?
All Honda Civic Hatchbacks have been raced and thrashed to death by 20 year olds. Not a good starter car as all the other 20 year olds had the same idea.
Check the Transmission fluid level it may be at the operational limit and sucking air. If not, get a newer vehicle and not a Civic :>)
Mar 09, 2016 | Honda Cars & Trucks
I have 1992 Honda civic and a Sony explode stereo
Your local ICE shop should have a jumper lead that hooks yours to the car harness. Most shops cater for the various multi pin plugs found on different makes.
Oct 09, 2014 | Cars & Trucks
Will a1996 honda civic front door fit 2000 honda civic dx
The body style was the same from 1996 to 2000 for the Honda Civic. Are both of the Civics similar in body style as in they have the same number of doors? Not sure if a wagon or hatchback would interchange with a regular 2 door coupe.
Mar 20, 2014 | Cars & Trucks
95 honda civic hatchback wont start
Did you hooks the the spark plug wires right. If these are not in the right order then you will have a misfire. If enough of them are out of place then you wont have enough fire to start the engine.
Mar 03, 2010 | 1995 Honda Civic
CDX-RA700 will not get power from my Honda Civic
Automobiles use Direct Current "DC" and is very dependant on a good ground. The black wire from your stereo should be the ground and needs to be attached to the chassis "metal part of the car". You can use an ohm meter to check for grounds by placing one lead on your door hinge (unpainted) and the other to where you are connecting your ground from the stereo. Be sure that this wire does not have voltage on it with the key off, on acc, or in the on position or you could blow a fuse or damage your equipment. Besides that make sure that you have 12v constant to the (usually red wire) and switched (voltage only with the key on) to (usually the yellow wire). Hope that helps. It's mostly about the ground.
Mar 10, 2009 | Sony CDX-RA700 CD Player
94 civic
no it doesn't the body is different so the doors are diferent. please rate
Sep 26, 2008 | 1994 Honda Civic
I need to know if i need to change the distributor from my 94 v-tec to my 97 civic hatchback
Yes, they are 2 different things in regards to how the engine computer reads it.
Jun 23, 2008 | 1997 Honda Civic
My starter
'94 through '97 should share the same starter.
Jun 14, 2008 | 1997 Honda Civic
Sony XPLOD CDX-GT200 CD Player Logo
392 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
