Question about Janome Mini Compact
My Janome mini compact will not sew through a double layer of flannel. I have tried changing the tension.
  • Janome Master
  • 7,365 Answers
Sometime the needle & thread are not compatable--try this & see if it work for you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Oct 14, 2010
Janome sew mini will not fill the bobbin
a part of the bobbin winder is not working and should be checked
Mar 25, 2014 | Janome SEW MINI Mechanical Sewing Machine
My brand new Janome Sewist 500 is making noise - it's clunking as I sew. I'm sewing two layers of cotton twill, stitch A, length 2, tension 5. Help!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
Mar 09, 2012 | Janome Sewist 500 Sewing Machine
Tension is too tight unable to loosen cotton breaks Maybe needs a service??
Before you do anything else unthread and rethread the machine again. Sometimes the thread gets hooked on something or wrapped around and will cause it to break. Of course do check the tension again too. Is it breaking when you pull on it before it goes through the needle?
If it is breaking when sewing then it could be that the bobbin tension is too tight.
May 27, 2011 | Janome Mini Compact
Is there somewhere I can order a replacement part for a Janome Sew Mini sewing machine? I need the little clear door that covers the bobbin compartment.
Try www.sewingpartsonline.com and put in Janome then your model number, they have all kinds of parts for sale. They may have your part or call Janome at 1-800-631-0183
Oct 04, 2010 | Janome Mini Compact
Type of needle for janome mini compact
Hi
Ask Jan on the Janome website.
http://www.janome.com/index.cfm/LearningCenter/AskJan
Or try on the forums there.
http://www.janome.com/fusetalk/forum/
I would imagine that Janome universal needles would be fine for this machine.
Thicker needles are required for sewing thicker fabrics.
Sep 19, 2010 | Janome Mini Compact
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Jul 28, 2009 | Janome Mini Compact
Janome left needle thread breaking CONSTANTLY
Sounds like a tension problem. Your machine should have two tension adjusters. One for each needle. The book that came with your machine will tell you how. Another possibility is a bent needle.
Feb 27, 2009 | Janome MyLock 634D Mechanical Sewing...
Owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Jan 25, 2009 | Janome Mini Compact
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Instructions
Try this website contact them if yours is not listed.
www.sew-europe.co.uk
Feb 02, 2008 | Janome Mini Compact
Janome Mini Compact Logo
97 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
