Question about HP DesignJet 9000 InkJet Printer
My HP designjet 9000s gives me error message 1180 when I try to use the print head recovery or when the printer goes into it's self clean. I have tried greasing the gears cams and shafts that raise and lower the capping station to no avail. The tubes under the capping station are not stiff. The thing is that the capping station seems to raise and lower just fine when starting up, printing or during manual cap cleaning. It is just when self cleaning that I get the error message. Does anyone have any idea what the problem is? Or at least a quick fix so that I can print while I am waiting for the repair tech?
  • grant681 Oct 14, 2010
    I don't have a help button. I have: Online - Shift - Cancel - Ok and four arrow buttons.
    President:
  • 4,070 Answers
HI! You did perform all the first course of action which I would too. It's just safe to wait for the tech before everything gets worse. Have a good one now and thank you for using FixYa!
Posted on Oct 14, 2010
System Error 1180 is a "Capping Motor Error"
Description:
Capping Motor over current is detected.
When the ambient temperature is very low, the pump motor tube becomes hard and the load on the Capping Motor is increased. The Capping Station has a torque limiter for up and down operation so that the capping station does not experience any over current. Apply grease on the shaft of the capping station gear so that it helps with rotation and make sure that the capping station cables are connected correctly and not damaged. If the Capping Motor cannot be rotated, replace the capping station. Replace the Main PCA if problem does not go away after completing the steps above
    Genius:
  • 1,478 Answers
I will advice you reset the printer, follow the steps below to reset the printer,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
See, if that fix the problem should be fix with this.
Take care.
Como reparar o erro 0040 da hp 9000s
The read/write of the print timing controller & print data distributor registers on the Carriage board was diagnosed & a error was detected.
Replace the Carriage board.
Make sure the Carriage cable is connected properly.
Replace the Main board.
Apr 27, 2015 | HP Vacuum Fan for DesignJet 9000s Series...
System error 1120 hp 9000s
HI,
Please reinstalled Printer driver or restart computer or printer then you new driver installed it. Or installation before scan virus and removed it. Or proper check it all connecting cables.
Read more Help.. HP DESIGNJET 9000S SYSTEM ERROR 1120 and HP Printer Support
Thanks,
Jul 10, 2014 | HP DesignJet 9000 InkJet Printer
Hp designjet 9000s system error 1701
The Paper-Axis or the Scan-Axis Motor moves the Carriage, but the input from
the Linear Encoder Sensor does not change.
You are going to need a tech to check out the plotter.
Dec 11, 2013 | HP DesignJet 9000 InkJet Printer
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Sep 30, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
How can i fix system error 11do on hp designjet 9000s
System Error 11D0: Cooling Fan Error
Description:
When the Printhead temperature reaches above 43oC, the Printer will check
whether the temperature drops below 43oC during printing. This error will
appear if the temperature does not drop below 43oC after 10 minutes.
Corrective Action: Try the following:
Make sure that the Printhead Cooling Fans are working correctly. If the
Printhead Cooling Fans are not working correctly, replace them.
Make sure that the Printer Cooling Fans are connected and working
correctly.
Oct 06, 2011 | HP DesignJet 9000 InkJet Printer
Error 1180 en hp 9000s que es?
Amperage in park station engine is too high. You should lubricate all gears around it.
Jun 28, 2010 | HP DesignJet 9000 InkJet Printer
HP DesignJet 9000 InkJet Printer Logo
418 people viewed this question
Seeker5211
Seeker5211
