Looking for a manual on the TRANE 3AAT80B1A1 - Heating & Cooling
Operating manual for trane sfhc40
this is all i could find to do with what you are looking for so not sure if this link will help you out.
manual for trane sfhc40 Google Search
Dec 15, 2016 | Heating & Cooling
I moved into a home that has the Trane Comfortlink IIXL950 thermostat. How do I reset the pass code?
Pages 17 and 19 appears to indicate the password is your Wifi SSID passcode
http://www.bayareaservice.com/wp-content/uploads/2011/12/TZONE950-Owners.pdf
checkout the other pages for WEP support and other advance settings for multi zone and schedules
Aug 17, 2016 | Heating & Cooling
I have a Trane 3AAT80B1A1 thermostat that I'm replacing with a Honeywell RTHL 3550D. Is it possible to do this myself or will I need to have an electrician come out?
The easiest way to be certain the wires get connected is to cut the wires close to the screw without loosening the screw. That way the color of the wire can be seen on the correct terminal without mixing them up.
Feb 24, 2013 | Heating & Cooling
What is the age of the following Carrier RTU - Model # YCDO6OC460BF & Serial # R28105287D I have been told 1982, 2000 & 2007. The unit does not look that old, so do not believe it was a 1982,...
YCD060 is a Trane unit number not a carrier. Trane has a large guide for looking up approximate age of equipment. There is no date coded in the serial number, Trane does include a mfg date on most of the labels on later equipment, look for it on top or bottom corner of label if you can still read it otherwise I have the cuide at the office and will look it up this week. FYI our company is a TCS Trane dealer.
Aug 24, 2011 | Heating & Cooling
Looking for a manual for a tappan furnace G5RA096C-20
tappan was purchased by GE and GE was purchased by TRANE best of luck the TAPPAN brand went out of business due to all the lawsuits during the 80's and we have been replacing them ever since. what is the issue with the ssystem the requires the manual. also get a CO2 monitor for your house if you don't have one already.
Mar 04, 2011 | Heating & Cooling
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Jul 27, 2009 | Heating & Cooling
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
