Question about Compaq Computers & Internet
Compaq FS7555 computer will not open the memory stick
    Novelist:
  • 142 Answers
Here are some steps that you can follow
1. Make sure that the USB point is working fine, you can check it by plugging any other UPnP device like printer etc.
2. Also make sure that the memory stick is itself working fine , you can check this by inserting it in any other computer.
3. Try to check it an all the USB points.
4. Goto My computer >> ( If u are able to see the icon for the USB memory stick, right click on it and click on open and check whether you are able to open it , or you can browse through My computer >> c: >> windows >> explorer and then see whether you are able to open it.
Posted on Jun 02, 2008
    Sergeant:
    Champion:
  • 326 Answers
Does Ur system see the stick? See My Computer.
Compaq fs7555 computer problems. How to do a factory reset.
Tap the F10 or F11 key (depending on model) repeatedly at startup, before Windows starts loading and then follow the instuctions.
Dec 27, 2015 | Compaq Computers & Internet
Error code ME516-12 ON MY COMPAQ PRESARIO PC
The error code you are getting indicates issues with physical memory (RAM) of the computer.
You need to open the device and see if there are two memory sticks inside. If you have two sticks, try to start the computer with one memory stick at a time. This way you will come to know which of the memory stick is gone bad.
Note: make sure every time you replace any part completely turn off the computer.
For any further assistance feel free to revert.
Jul 14, 2012 | Computers & Internet
Compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Feb 23, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
How to remove black borders fom aroun screen on compaq fs7555
I think you resolution is not configured correctly. Try changing resolutions. var fctb_tool=null; function FCTB_Init_1fbef43845f44d14832cf8c0939244b7(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_22d0cd4007e646a49bd1ab3f825da4fa(t) { fctb_tool=t; start(fctb_tool); }
Dec 10, 2010 | Compaq FS7550 17" CRT Monitor
When I start-up my Compaq Presario S4200NX - I get the Compaq logo and a continuous beep and it doesn't go any further. I've read some posts and its pointing to the memory card being bad. Is this the case?
It is possible that the memory sticks(RAM) are busted or cannot be read anymore. If you have multiple memory sticks, try isolating the damaged memory stick by using 1 memory stick at a time and try starting your computer up. Once you have found the busted one, try replacing it with a new one.
Hope this helps!
Sep 08, 2010 | Compaq Presario S4200NX (DF215AR#ABA) PC...
COMPAQ PRESARIO SR1420NX, TRYS TO POWER UP BUT GREEN LIGHT ON FRONT POWER BUTTON JUST FLASHES..
Could be one of two things: either the power supply is going bad or the RAM is either going bad or isn't seated properly inside.
First thing I would try would be to re-seat all the memory chips inside the computer. There could be up to 4 sticks of memory in some computers. If this doesn't work, try pulling the memory out of the computer one stick and a time and booting the PC. If it boots, you've found your bad memory stick. Put all the others back in and replace the faulty one.
If none of this works, you might consider calling HP (maker for compaq) for support on getting the power supply replaced.
Jan 19, 2010 | HP Compaq Presario SR1420nx...
Compaq Presario S5200NX will not recognize memory stick
is either you reload the computer system or u buy an internal or external usb card.or check the connection cable inside the computer machine if it is properly connected
Jan 16, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Putting information from my computer onto a memory stick
Hello my name is Tim, First thing you are going to want to do is insert the memory stick and open it, if it doesnt automatically open try going to "my Computer" and locate it. then make sure there is sufficient memory on the memory stick. leave this window open and also oper the window with the pictures, you will need to drag each photo you want into the window that has your memory card, or you can select the whole photo folder by holding ctrl and pressing a. to select multiple photos to drag and drop but not all try holding ctrl while clicking on the photos you want then when you get them selected let go of ctrl and click and drag one of the highlighted photos to the memory stick, this also works with files. I hope I answered all your questions, Please leave feedback on me and let me know if you need anymore help. Thanks, Tim
Mar 13, 2009 | Compaq Computers & Internet
Sound not playing
did u install sound driver which will be in motherboard CD...
Sep 26, 2008 | Compaq Computers & Internet
USB port
Have you confirmed that none of them work? Do the USB ports show up in device manager (look for USB Root Hub entries).
If all else fails, you could always buy an internal PCI card that has USB ports on the backplane.
Does your digital camera have an SD card or other memory slot that you could simply plug into your desktop to transfer your pictures?
Mike
Dec 10, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
