Question about HP L1706 17" LCD Monitor
Hp 1706 monitor how to disable osd control. how to disconnect the wires?
viziks
  • 220 Answers
SOURCE: OSD
The problem should be defective keypanel.Try replacing the switches .
It should solve your problem.
Please provide feedback and rate this solution.
Samir
Posted on Apr 08, 2008
  • 62 Answers
SOURCE: OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Posted on Nov 03, 2008
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Posted on Jul 18, 2009
  • 156 Answers
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Posted on Nov 30, 2009
SOURCE: How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Posted on Jan 20, 2010
I have a hpw2207h monitor that says osd lockout !!!!!! How can i fix it? Thanks
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 18, 2011 | HP w2207 Monitor
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
I have a hp monitor with the number hpf2105 on it
Please see my profile for instruction, or try below, you should also download user manual from HP:
? OSD Lock —The OSD can be enabled or disabled by
“SD Lock”displays for 10 seconds.
?If the OSD is locked, press and hold the Menu button for
?If the OSD is unlocked, press and hold the Menu button
May work the same on other HP model also.
User manual: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
If you want to see the inside of your monitor, look here:
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | HP f2105 21" LCD Monitor
Nov 30, 2009 | HP 2009M Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
OSD
Samir
Dec 11, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP L1706 17" LCD Monitor Logo
157 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
