Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
No sound from built-in speakers
I am getting no sound from the built-in speakers on this monitor. I have attached standard speakers to the tower and have managed to obtain sound, but it too is not working correctly. The volume is very low even though I've gone thru all the "chcklists" and levels are set as high as they can get. HELP??????!!!!!!!
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
Sep 26, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
My desk top moniter has built in speakers which have stopped working. Tried attaching a pair of speakers to moniter....nothing. The computer shop said it's most likely a Windows problem and to bring in...
Make sure the Volume is high on the monitor as well as on the PC. the speaker cable that is connected to the back of the tower to the back of the monitor you have to connect that speaker cable to the front on the tower in the headset port and try to play some music. that should work out if there is no issue with the sound driver.
You can uninstall the sound driver from the device manager and reinstall it. update the driver.
Aug 09, 2010 | Computers & Internet
I have a liteview moniter but when connected to my computer it has no sound is there somthing wrong with the comp or the moniter
Most monitors dont have built in sound so check for a sound connection from the monitor. Check the cable where it connects to the PC, if there is a small light stereo plug, stick it into the light green connector on the back of the PC tower. The standard video cable does not have the connections for audio. If you are using a HD monitor that has inbuilt speakers, try using the HDMI connector if it has one, this does have the audio inbuilt, Some DVI cables have inbuilt audio, some do not, look for small round 2.5 mm stereo plugs not connected into anything..
Oct 15, 2009 | Computers & Internet
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
Hp w2207 monitor has no sound
Does the moniter have internal speakers? If so then there is a volume controller option on the moniter or else you have to use external speakers.
Jun 14, 2009 | HP w2207 Monitor
the speaker cable goes into the green 1/4 inch pin jack on the tower the pink is for microphone and, blue is line the monitor should have the same markings
Jun 01, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Pls check if the audio cable from the monitor is connected to the tower. Make sure it is connected to the green port at the back.
Also check the volume button on the side of the monitor and set it to maximum.
If this doesnt work, then try with another pair of external speakers and check.
Jan 22, 2008 | HP vs17
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
80 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
