Question about Kitchen Appliances - Others
Rowenta TP100b toaster--can it be rapaired? - Kitchen Appliances - Others
How to turn on the steam, there is water in the iron
See video Rowenta DW2070 Effective Comfort Iron SKU 7936487
1. Connect the Iron to wall outlet.
2. Turn the central dial to desired temperature setting.
3. Press the two switches with your thumb while holding the iron.
4. One switch is for cold water spay from nose and the other is to release steam from .
Mar 19, 2016 | Rowenta Effective Iron
How can I turn on the steam?
If the iron has been used for some time, it may have become clogged and is unable to generate steam. If you do not hear sounds of water boiling, the heating element may have failed.
Is a Rowenta DW 5080 240 volt available for Australia
all electrical equipment imported into Australia have to conform to Australian electrical regulations and that includes insulation properties ,voltage
Basically if it is not on the market then it is not 240 volts so if you are considering buying overseas then it is not advisable as it will be the wrong voltage and will fall short in meeting the strict regulations for electrical equipment
Aug 22, 2015 | Rowenta Dw5080 Focus 1700 Watt Steam Iron...
How do i fill water in the rowenta effective?
Use a small container of bottled water.
Dec 18, 2014 | Rowenta Effective Iron
To-38a owners manual
I need the spring contacts for a Rowenta Long Slot Toaster Model TO-38A. Can I still buy this part?
Apr 21, 2013 | Rowenta Kitchen Appliances - Others
White stuff coming out of my iron
Spring water has minerals in it.If you want to be sure the water is pure,distilled water is best.(My city water is full of minerals,which means a cleaning with CLR is necessary quite often for my coffee pot and shower head).Distilled water was recommended for topping off car batteries back in the day before they were maintainence free.
Jun 02, 2012 | Rowenta Effective Iron
Cannot clean crumbs from bottom toaster also need .manual
Hello, gwillia
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Aug 20, 2011 | Rowenta TO-812 Brunch 2-Slice Toaster
Help with toaster. anyone there?
Well, I'm not a toaster pro, but I do make my fair share of toast.... I have an idea for you, I researched your product and couldn't find any specific help but try this:
Unplug your toaster, firmly hold the mechanism in the down position as far down as it will go, then turn the unit upside down, give it a good shake and flip the lever a bit. Reinvert, plug it in and see if you've got any improvement. (I think I learned this trick from the Andy Griffith show... you know old Emmett and the fix it shop) let me know if it worked! Sorry I can't be more help.
Dec 12, 2009 | Rowenta TL900015 2-Slice Toaster
Rowenta toaster with a heating element that does not heat
you can get parts for this unit . if you did you cannot change an element there rivited in there at the factory , not made to repair
Feb 18, 2009 | Rowenta TO818 2-Slice Toaster
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
