Question about Kenmore Kitchen Ranges
Left front element not working ordered new element and replaced and it still isn't working. the element on light comes on but does not heat at all
    President:
  • 1,430 Answers
Did you check the receptacle that the burner plugs into? Sometimes they get melted or corroded. If that looks good the problem is likely in the switch. They are easy to check and replace. Here is a couple links that should help
Testing an infinite switch
Burner and receptacle
Posted on Oct 14, 2010
Ariston ASL 70 replace heating element
hi if its like hotpoint 2 skrews on back lift front push back and lift off looking at back take skrews down left hand side ease panel off comes toward you just check none on bottom edge 1st once off you will see wires coming through bach to a sqaure plugmake sure not just themostat gone
Jan 26, 2013 | Hotpoint Ariston ASL 75 CXS NA Electric...
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
Gas oven isn't heating up, the heating element is working but the rail isn't lighting, what needs to be done?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 27, 2011 | Maytag Microwave Ovens
Left large element is not lighting up or getting hot. Replaced elements still not working.
You might want to check the connector where the element plugs into. Often times when an element goes bad, it's contacts heat up from arcing and crystallize or even burn causing a condition where there is no contact with the new element. Remember to have the power off when you start checking them. If that isn't the problem, you would have to check the voltage at the switch. It could be a defective switch also.
Jul 19, 2011 | Kitchen Ranges
My question is in regards to my Kenmore electric range, Model: 790.96219407. The left front element is not functioning. I tried replacing the left front element but this did not work. Could it be in the...
It is usually always an infinite switch, Rarely is it a surface element. The fact that the power light does not go on is also a good clue that your switch is bad. If it was a problem with the wiring to the element, your light would be on. When you order the switch, ask for the exact origional replacement. They have some generic switches that have shafts that have to be broken off to the right size for your range. These are not as reliable as the origional which usually has a much stronger shaft. Good Luck, Appliance Specialists.
Jan 26, 2010 | Kenmore 96212 / 96214 / 96219 Electric...
Dryer won't heat
I have a F&P dryer DEGX1 about three years old , followed kristi's advice and it worked. There are two screws holding the information panel on, inside there is a schematic with instructions on how to put the dryer in diagnostic mode and how to take the front panel off. i reset the breaker located at the bottom of the front panel on the heating element box and put it back together and it worked.
My vent cover outside was frozen shut and this caused the breaker to blow saving the heater elements, am changing the vent cover to a different design to prevent this happening again
Jan 26, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Kitchen Ranges Logo
100 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
