Question about Destroyit 3802 Shredder
Cross cut Ideal Mode 3802 will not turn off. Cleaned magic eye and same problem
Shredder is jammed. Won't work.
If the shredder has power, the sheet detector may be blocked by a scrap of paper. Also, cross cut shredders that are an integral unit are best cleaned by turning them upside down to get access to the mechanism. Finally, if the motor became very hot an internal thermal fuse may have opened in which case the shredder will have to be replaced.
Dec 17, 2014 | Omnitech 12 Sheet Cross Cut Shredder
Audio getting cut during peaks ..
You are driving the receiver too hard on the peaks so it is temporarily shutting down for protection.
Mar 23, 2014 | Denon AVR-3802 Receiver
I have a ID Armor 15-Sheet Cross Cut Shredder.. The problem is it runs constantly on the auto position.. I cleaned the paper eye with canned air & swabs but it still runs all the time.. Can you suggest...
lots of shredders having problems like this. Easy way is to turning off the machine when you don't use it. Harder way is to disassemble it and clean everything you can. Maybe you will have to replace a sensor with new one. You have to spend some money:(
pifonski
Feb 19, 2011 | Office Equipment & Supplies
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
My Royal VF700 shredder will not turn off
Try giving the EYES in the middle where you insert the paper a clean...if that dosnt work you may have lost the pcb inside ...give Royal a call at 1-800-524-0799 for parts assistance.
Feb 24, 2009 | Royal VF700 Cross-Cut Shredder
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Won't stop running in auto mode
This is an issue with the paper feed sensor if it is mechanical switch there may be paper holding switch in active position if it is a elecronic sensor (looks like the bulb on the end of a remote located in the center on both sides of the paper slot) it may simply need to be cleaned with a Q-tip dipped in rubbing alcohol. If cleaning or unsticking switch does not work you will have to contact the manufacturer for any parts replacement.
Mar 15, 2008 | IdentityGuard Cross-Cut Shredder
Denon 3802
m8 think thers hardware problem with it.or it could simply b that wen you pushin the amp hard then some other buttons are gettin pressed at the same time on the bord. couldnt say for sure without taking a look you could send it to these guys an they should do it pritty quick and cheap. http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Denon AVR-3802 Receiver
Destroyit 3802 Shredder Logo
111 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
k24674
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
