Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Techwood 42inch plasma
Hi ,
I have had my plasma for just over 3 years, however the past month black vertical have appeared sporatically, now we have had 2 lines right down the middle, its stays on for hours and only goes away for ten minutes, then back on again.
I have disconnected all other appliances and line still there so not a singal problem.
Do you have any ideas as seems a generic problem with alot of plasmas ???
Do i need a new tv or an expensive repair, I hope not.
I would really appreciate your advice.
Carole
  • Anonymous Jun 07, 2008
    black line on left side of screen on my 42inch techwood plasma comes and goes any help appreciated
  • sansahota Sep 08, 2008
    I have a new techwood plasma 42 inch for over a year now and brought it second hand, suddenly the tv has got two lines going down the screen ,I have tried everything but the lines would not go . I have changed the wires ,scart leads and disconected from main power supply a number of times but these line just come and go.
Black line probl;em with this model is caused by dry joints on the resistors that are attached to the individual ribbon cables. a fairly easy fault to repair. but it means undoing all the screws and resoldering the resistors. once the back of the tv is off, locate the offending resistors and resolder them,Take the two screws that hold the ribbon cable assembly and gently lift out the ribbon cable. just use a hot enough soldering iron (mains or portable gas) and watch the solder 'flow' attach the ribbon cable. if you're careful, you can test to see if the fault has been repaired prior top replacing the cover. (make sure there's no pets or children nearby and be very carfeul as there's live mains within reach. once you're happy the fault has been repaired, put the cover back on. Its worth resoldering all the resistors just to save the fauklt reoccaring anywhere else. dominic :-)
Posted on Dec 02, 2010
Same happened with mine... its a screen fault and your tv is dead. currys just sent me £1000 worth of vouchers as it wasn't worth the cost of fixing it.
Posted on Aug 21, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Techwood 42 plasma
if you still need the fix for this repost i have just repaired mine i had a 1 inch thick line just off centre .this is a easy fix no parts required.
Apr 19, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Red Vertical Line and Black Screen, Sound OK
Check this out
http://forum.eserviceinfo.com/viewtopic.php?t=30810
have a nice day
Oct 08, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
30mm. vertical black line on screen.
Hi I have just fixed this problem on my screen. The fault was a dry solder joint on the driver circuit of the screen. Have a look at my thread here. I have tried to explain it as well as possible. Hope it helps.
Jan 22, 2007 | Hyundai ImageQuest HP4240 42 in. Plasma...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
328 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
