Question about Samsung Computers & Internet
MY MONITOR IS SAMSNUG BH68-300165J-02 HORIZONTAL LINE IS SMALL VERTICAL LINE IS GOOD
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: boka monitor problem
Below are images of the vertical IC of a Boka MO-15NF. The first shows its general location which is almost at the center of the board.  The second is a close-up.  Hope this be of help. Good luck and kind regards.
Posted on Oct 26, 2007
  • 3 Answers
SOURCE: Small annoyance with HP P1100 monitor. Slightly darker vertical lines.
Sounds like dried out electrolytic caps. How old is the monitor ?
Posted on Dec 19, 2006
Benimur
  • 6966 Answers
SOURCE: Horizontal lines moving vertically from bottom to top of monitor screen
Your post/description indicates a likely AC hum riding on the video signal. This cold be caused by:
  • loose cable/connector;
  • faulty capacitor on the unit's power supply regulator circuitry;
  • electrical intereference which could be caused by external drives, subwoofers, electronic ballasts of some lamps, any electrical/electronic devices physically near the monitor.
The 2nd possibility would mean that the unit has toi be opened. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 23, 2008
  • 98 Answers
SOURCE: The Acer monitor's horizontal and vertical is set
use the function button on your moniter and scroll until you see the setting you want to change and increase it or decrese it from there.
Posted on Aug 03, 2009
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Horizontal and vertical lines
Have you tried to run diagnostics at boot-up?
Have you tried to test with a known good graphics card?
Have you tried testing with another known good monitor?
Other issues would be corrupt video driver(s).
Feb 07, 2012 | Dell XPS 630 (DXDGCC3_6) PC Desktop
When I turn on computer, the monitor say going to dpm mode. any help?
DPMS (Display Power Management Signaling) is a standard developed to save energy and maximize the useful life of computer displays. By switching the horizontal and vertical sync lines on or off, a DPMS compliant video card provides the capability to place the monitor into one of four modes (Normal, Standby, Suspend, Off).
Each mode puts the display into a different powered state from fully powered up, to the Off mode. In the Off mode, only a small auxilliary circuit is running which monitors the horizontal and vertical signals to wake up the monitor.
Dec 21, 2010 | Computers & Internet
Horizontal line problem
Cl;ick on Link Below, Good Luck.
LCD Help
Helping you with questions and issues you may encounter with computer LCD displays. ... you would receive a solid black line going vertical or horizontal.
Please dont for get to Vote, Thank you
Dec 16, 2007 | HP D2835 17 in. CRT Monitor
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Very fast lines appearing on screen
it is due to video failure
check computer to monitor cable for loose.
check crt base for loose.
check connector going to crt base
check for video supply.
if you are not tech person take the tech help.
good luck.
Oct 15, 2007 | LG Studioworks 563N 15" CRT Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
89 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
